Fueling for a 100 hp wet shot
I'm looking to install a nitrous express wet kit with a 100 shot on my H/C/I stock bottom end ls1. I'm going to use all the necessary electronics to pull timing, the lnc-2000, an innovate Motorsports psn-1 for a window switch, wideband, bottle pressure and safety controls. The kit is the basic Gm efi kit from 2007 that I've never used till now. My question is, what do I do for fueling? I know I need to upgrade my stock fuel pump but to what? If I upgrade to a 340 pump, do I need a regulator? A Hotwire kit? Whole new supply line or are the factory lines sufficient? Also, it has the shark dual knozzle, is that decent or should I spend the money for a plate to match up to my fast 92? All input is appreciated. Thanks in advance. Also, sponsors, I still need to buy all my electronics and accessories so who's got the deals? Black Friday?
Chris, for sake of increasing spray or possible boost down the road, do you know or anyone know what a 340 pump with Hotwire harness would be good up to hp wise? I'm at 460rwhp now n/a and I can't see myself making more the 650 rwhp with the car on spray but we all know that you get used to a certain power level and am always looking to the next step up.
That's why I would say go bigger if you plan on increasing down the road.
I'll see if racetronix offers a 340 pump with a Hotwire kit and go with that. Cause yeah, I don't want to change it down the road if I get brave and want to run a bigger shot.
