LS376/525 + 150 Shot
Old 11-22-2015, 01:29 PM
dalessandro12's Avatar
Default LS376/525 + 150 Shot
Hi,
I'm in the middle of putting together an LS swap into my '70 Nova. I plan on going with an LS3 but not sure if I am buying a crate engine or a custom forged motor.
My goal is to run 10's in full street trip. Will the LS376/525 crate engine and a 150 shot get me there? I think so but thought I would ask. My car will be running a built 4l60e, 3200 stall, 3.70 gears through a Currie 9inch rear and I'll run slicks at the track.
Thanks,
Daniel
Old 11-22-2015, 02:41 PM
98z28jorge's Avatar
I'm pretty sure it will
Old 11-22-2015, 02:57 PM
I had one guy on a Nova forum say that he had this crate engine in a Camaro and it went 11.3 on his first trip to the track in full trim.
The guy in this video also has a Camaro that went 11.7 as well.
I think a 150 shot, stall and slicks will get me there.
Old 11-23-2015, 12:54 PM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
It should get you close to what you are wanting but you will need to adjust suspension, tune, etc... to get you there ultimately.
-Chris
Old 11-23-2015, 01:57 PM
-Chris
Thanks Chris. I will have it tuned on the dyno to get it dialed in. I also plan on installing some Cal Tracs in the rear with some QA1 adjustable shocks, new upper/lower control arms and shocks in the front and stiffening up the sub frame.
Old 11-23-2015, 02:45 PM
Sounds like you are on the right track! With all that I think your goal is very obtainable.
-Chris
Old 11-24-2015, 10:10 AM
70LS1Nova's Avatar
10.9...sure. 10.2...depends if you go with the crate motor or the custom forged motor.
Old 11-24-2015, 11:03 AM
I think I'm leaning away from the forged motor. For my power level and goal, I don't think it is necessary. I am however, debating on the standard LS3 (430hp version) and swapping in a BTR stage 3 cam, CNC heads and thinner gaskets to bump up compression. For close to the same price of the 376/525, I'll have about 60-70 more RWHP. Add 150 shot on that and I think I'll see mid 10s.
Old 11-24-2015, 01:43 PM
Definitely go with the cam and heads because that will help you get what your wanting to run. Even with H/C you can still spray 150hp on that setup easily.
-Chris
Quick Reply: LS376/525 + 150 Shot
