150 shot, stock fuel pump?
You're playing with fire IMO. You already have a cam and other mods. Why risk it when you can get a Racetronix plug and play kit for a few hundred? Racetronix kit info can be found on our website:
http://www.harrisspeedworks.com/shop/home.php?cat=330
Matt
Matt
That'll work too. If you go that route make sure you also run a new wiring harness for the fuel pump (or else it will be just as if you had a stock pump) and you'll loose some functionally of the stock fuel system when you cut the bucket up. But it will work.
Matt
Matt
Originally Posted by MetallicaMatt
just drop in a Walbro 255
thats what I did, costs like 100 bucks if that. much cheaper than racetronic and easy to do
Matt
Matt
hurm, i just stuck with the stock wiring harness. I did go with the Walbro 255 "forced induction" model. still probably just fine
If you kept the stock harness installed how is the fuel pump going to get more voltage? It's going to get the same amount as a stock fuel pump. You have one piece to the puzzle, now you just need the other. We have the wiring harness; they just aren't up on the website yet. Let me know if you have any questions.
Matt
Matt
So the racetronix kit is a direct bolt in? No type of tuning or anything has to be done
? How is it better than the stocker? Does it just bump the fuel pressure up? Wondering becasue I will be getting some ported heads sometime in the near future and Iwould like to add a 100 wet shot on top of that. So i need to upgrade the fuel system. Just wondering if the racetronix is my best option. Thanks guys.
Originally Posted by HAULNTA
Is anyone spraying a 150 shot on a stock fuel pump?
