My car leaks oil after I spray!!!
Everytime I've run my nitrous after I get back my car leaks oil. It looks like it's coming from the back of my oil pan (please god don't let it be rear main seal). Any ideas?
75k miles, 125 dry shot, just barely installed about two weeks ago and I've sprayed 8-10 times. It only leaks after I spray but it may be my dipstick good point.
Originally Posted by ehirst83
??? Wet and dry? I've only heard of one kind of compression test can you tell me a little more?
A dry compression test is just a regular compression test. For a wet test, follow the same procedure but use an eye dropper to squirt alittle oil in the cylinder. If the rings are worn the oil will seal them and you'll see a big discrepency in the dry to wet numbers.
It would probrably be easier just to do a leakdown test.
I used to drip oil from behind the block everytime I sprayed my 150 TNT shot. I just figured it was too much crank case pressure and ran it anyway. Never had a problem other than a oil spot in my driveway and some melted plugs, but the plugs were a whole other problem. I do have a 98 and it was the only year of that shitty PCV system, so I just never worried about it. I guess if its leaving a huge spot where your putting more oil in every week it would be a bigger problem than I had, and should be looked at.
