View Poll Results: Most Reliable RPM Window Switch?
BMN Digital
11
14.10%
MSD
30
38.46%
MSD Digital
25
32.05%
NX
0
0%
Other (Please Specify)
12
15.38%
Voters: 78. You may not vote on this poll
Who has not had any problems with their rpm window switch and what brand is it? Also, is it digital or does it take "pills" (analog)?
Thanks!
Thanks!
I have a window switch from Baker Electronics, it comes with 8 different preset RPM windows that you specify when you order it which allows you enough settings to mess around with to see what works for you. It is small and wiring is simple. No pills with this switch. It is also faily cheap, I got mine brand new for $50. Haven't had a problem with it yet.
I have the MSD Digital and it has worked flawlessly..Can change RPM settings on it in the car in seconds and don't have to fumble with pills or little screw drivers to get covers off...Plus for around $85 its a real bargain...
I went out and bought an MSD digital and wired it up last night. Tested it today in the garage and on the street and it's working 100%!
One note: Don't follow the instructions and use Cylinder Mode 1 for the LS1 motor. It doesn't work. Use the 4 Cylinder mode as we normally do and it'll work fine.
Originally Posted by 1ScrudeDude
XTrooper, I thought you had a BMN
Originally Posted by XTrooper
I did and I ran my 11.47 run with it, but I decided to swap it out for the MSD digital.
Are you ok without the 1st gear lockout? That's what swayed me to BMN.
1st gear with 4.10's and MT Radials = 1st gear lockout
1st gear with 4.10's and 28" slick = Let her rip!!
That's cool.
I started spraying at 4 grand in 1st with no problems.
Not sure if my stock 16" wheels with the MT 245's will take ~540RWTQ on the dope in first, but well worth the try
