cam + nitrous question
Old 09-11-2005, 09:36 AM
WutupYo's Avatar
Default cam + nitrous question
so i am contemplating buying this cam i found from someone. he says it is made to be put in a stock motor, which he had it in, and he made 393 to the wheels.
my question is if i put a hundred shot on top of that, will my engine still be able to handle it safely (all stock) or will i be asking for trouble?
thanks for your help
Jason
Old 09-11-2005, 09:44 AM
XTrooper's Avatar
You'll be fine. My motor (and lots of other guy's motors) still has its stock bottom end and handles the added power with no problems whatsoever.
Old 09-11-2005, 09:58 AM
WutupYo's Avatar
ok, but i wouldn't have to upgrade the rockers or rods ar ANYTHING? i mean i know the cam will be fine on a stock motor, and the nitrous, but i don't know if they would be fine combined with each other...
Old 09-11-2005, 10:01 AM
Turo's Avatar
It will be fine, just make sure to get at least a fuel pump and a good tune.
Old 09-11-2005, 10:12 AM
WutupYo's Avatar
alright that makes sense, thanks
WutupYo's Avatar
Old 09-11-2005, 10:42 AM
XTrooper's Avatar
Oh and get a set of colder range spark plugs. That's a must.
Old 09-11-2005, 02:01 PM
Matt@HSW's Avatar
Your engine will be fine. You might want to upgrade your fuel system though.
Matt
