"BIG DOGS" inside please
Old 09-16-2005, 01:45 PM
7 Second Club
ty_ty13's Avatar
Default "BIG DOGS" inside please
i have a delimma on my hands I'm getting a 408 this winter but im not sure if i want to go FI or N20.... I already have a fogger systemd with 4 noids that can support every bit of a 500 shot....
my question is... Whats the Fastest times for a 400+ CI block and what is the highest rwhp...
if i can still get the power and ET i want out of the N20 ill stick with it.
some one please chime in...
I want atleast 9.20's... id love to be high 8's with N20
or 900+rwhp
Old 09-16-2005, 01:49 PM
Vax
Vax's Avatar
what are the rest of the specs on your motor, cam #'s etc ?
Old 09-16-2005, 04:08 PM
7 Second Club
ty_ty13's Avatar
specs of what motor?
as of right now there are no plans but to get a 408.... so what should i do?
Old 09-16-2005, 05:35 PM
Matt@HSW's Avatar
1000 + RWHP would be doable with the proper set up. Figure in at least 12:5.1 comp, solid roller, and a good set of heads. We're finishing up a 383 that will be right around there.
Matt
or 900+rwhp
Old 09-16-2005, 06:18 PM
383LQ4SS's Avatar
I am shooting for between 900-1000 rwhp on my 415 solid roller. Thats roughtly 750 rwtq at 7000 rpms = 999 rwhp.
I really dont think it will be that difficult...we made 868 rwhp on a mild hydraulic cam 408 ci setup that made right around 500 rwhp on motor. It was a neat...but fairly basic setup using dual stages dry/direct port controlled by the NX dual stage controller.
I believe you will need to use either staged nitrous or a controller.
I will be using the Maximizer.
BTW..My 415 ci motor and nitrous setup may be for sale in a few months.
Old 09-16-2005, 07:28 PM
Elite_Hot_Rod's Avatar
I'd say a low compression 402 with a good sized turbo would be the way to go if you have all the other stuff to support it.
Old 09-16-2005, 08:06 PM
7 Second Club
ty_ty13's Avatar
turbo = $$$$$$$$$$$$$$
Old 09-16-2005, 08:38 PM
6 Second Club Moderator
LASTLS1's Avatar
or 900+rwhp
I would say iron block, 1/2 '' studs and oring the block. Keeping head gaskets in the motor is the trick, tons of cylinder pressure. That aside your et goal should be a walk in the park.
Old 09-16-2005, 08:40 PM
gator's 99TA's Avatar
ARE with their silver Z made 1K rwhp through a th400 YEARS ago. ran 8.50 @ 165ish before anyone was going fast. 422 solid roller with a direct port.
Old 09-16-2005, 09:14 PM
DOC OTIS's Avatar
I'm shooting for high 8's on pump gas with my solid 427. Not sure what shot yet, but I can go to 500 if needed. Should fall somewhere between 900-1000 rwhp depending on the pills.
Although I'm starting to think that a turbo would be the way to go if I were to start from scratch. I started adding up all my n2o crap and realised I could of done a turbo for not a whole lot more. There is nothing cheap about n2o when you spray a big shot. My new setup is going to burn roughly 7 pounds a pass when it's on kill, ouch, good thing I have a refill station in my trailer now.
Old 09-16-2005, 10:43 PM
Your right about the cost of a turbo set up but I think it would be more durable in the long run. My 408 makes 484 RWHP N/A and 725RWHP on a 300 shot. It ran a 9.23@149.1 MPH at last years Thunder Shoot out. As has already been stated the hard part about a high compression 408 on the bottle is keeping the heads down. If you are intent on building a 408 on the hose use 1/2" ARP head studs, "O" ring the cylinders and use head blanks with thick deck heights.
Old 09-17-2005, 03:47 AM
red90cobra's Avatar
if your worried bout the money you shouldn't be thinking of a turbo setup. if I could do it again it would be with a big 106 or something along those lines
