Forged pistons and Ring Glands (N20)
Old 10-26-2005, 09:30 PM
ATLHwyRacer's Avatar
Question Forged pistons and Ring lands (N20)
Ive heard of guys cracking pistons down to the top ring land using stock pistons while spraying nitrous (100-200 shots), will forged pistons ever crack?
What caues this crack to happen and why is upgrading to a forged piston important?
Old 10-26-2005, 10:11 PM
SLowETz's Avatar
Uhhmmm.... it's ring LAND.... not ring gland.... but you prolly knew that
Anything can break given enough stress. A forged peice is your best bet for longevity in a PA motor. With a propper tune, it(forged piston)will last as long as a stock peice used in a stock application.
The reason guys are craking ring lands is :
A) too big a hit on a hyperutectic(cast) piston..... or....
B) too big a hit on a ragged edge tune..... or....
C) A&B
Old 10-27-2005, 04:44 AM
XTrooper's Avatar
A 200 shot, maybe. On a 100 shot with a proper tune? Highly unlikely.
Old 10-27-2005, 10:55 AM
LOnSLO's Avatar
Running too rich will lift ring lands like no other. Too lean will start to burn the piston if temps get much above 1500 degrees. With a hyperpathetic piston, which has no tolerance for detonation, it will simply crack apart and/or explode. The forged piston can handle much more detonation and heat, but still has its limits.
Old 10-27-2005, 11:14 AM
Ahh ring land!
What sort of limits L0nSl0?
Also on the topic of DP systems, are these harder on the pistons than a convention Wetkit?
Old 10-27-2005, 12:15 PM
LOnSLO's Avatar
Ahh ring land!
Limits depend on piston design, but let's not get into that.
Old 10-27-2005, 12:17 PM
redline2k's Avatar
It can be done you just have to be real talented. That is how I destroyed my stock motor.
Old 10-27-2005, 12:48 PM
Diamond forged pistons flat top with -7cc reliefs
Old 10-28-2005, 06:56 AM
XTrooper's Avatar
Ouch. Sorry to hear that.
Old 10-28-2005, 11:15 AM
Here is a picture of what im talking about.
Old 10-30-2005, 01:27 PM
redline2k's Avatar
Its all good. It is bigger stronger and faster now,
Old 10-30-2005, 09:48 PM
V6 Bird's Avatar
C) A&B
Dont forget the real problem. Ring gaps not meant for big shots of nitrous.
Stock ring gaps are the reason that people break pistons. Use a good low tension ring and youd be surprised how strong they really are. I was spraying over 235rwhp worth of juice on mine and it was all good. What wasnt was the fact that I broke one my low tension rings sliding the pistons back in the block and didnt want to wait on them supplier to ship me a new one. I used a stock ring with matching gap as the rest, but its also a cast ring. Its closed up and broke the ring land. All the other pistons are perfect and all look black.
Old 10-30-2005, 09:49 PM
V6 Bird's Avatar
ring gaps too tight and using a cast ring. Use some good low tension rings, gap the top ring at .024 and the 2nd ring at .028, stock oiling ring and you will be good to go. Just dont break a ring when putting the slugs back into their holes.
Mike
Quick Reply: Forged pistons and Ring Glands (N20)
