LS1 Nitrous Wet Kit
LS1 Nitrous Wet Kit
Just got a couple of dumbass questions but would like to really learn. When installing a wet kit what is messed with and needs to be adjusted? What step by step procedure do I take on the install? Any fuel lines tapped or anything?
Virtually every decent wet-kit will have an instruction booklet included. Basically you install the bottle/blow-down tube, run the nitrous line, mount the 'noids and run electricity, mount a throttle-switch and tap your fuel line. The nitrous section has a wealth of info and many manufacturer's reps and suppliers post there.
NX LS1 Wet Kit
Also curious about a remote bottle opener, bottle heater, and purge kit. Where would be a good place to mount it all?
Anyone have any pics of the install? Especially where the fuel line has to be tapped?
Go to the NX website they have all the install instructions you need for everything. You will tap the fuel rail at the test port, which is just a schrader valve like a tire has. Look at your rail and youll see what i mean. Only adjustments you need to do are for the nitrous and fuel jets once you get it all installed. Common bottle mount places are on the hump between the back seats, in the wheel well, t-top holding area, or right behind the back seats. A heater is a great thing to have, especially if it is cool where you are. Purge will allow you to clear out the nitrous line of gasous nitrous before you spray it, it will help the nitrous kick in a little quicker. remote opener is a nice convienence to have also. Like I said, just go to NX's site, they have all the install instructions there.
Thanks for the help. I do have but one more question.... Is there any switch panel that will fit in that little cubby hole not too far from the shifter underneather the heater/ac controls?
1 Post
Re switch panel - go to http://www.nitrousexpress.com/Pages/Switch_Panel.htm
Shirley Temple Drinker
I would suggest this one personaly, looks better imho, and that cubby hole your eleminating is pretty usefull imho, can store a Ipod or cell phone, something like that
http://jimmy-jams.tripod.com/ashtrayplates.htm
I personally really like the new switch panel that Nitro Dave is selling that goes in the center console. Uses quality switches mounted in aluminum that is made to fit in the console and still leave room for whatever else you want to store in it. You can also get the switch panel to include an electric bottle pressure gauge. Not to mention it is concealed, so there are no switches or pressure gauge in site (for those of you that like to hide things, haha).
I like the NX switch panel that you can put in the cubby hole in front of the shifter, just below the AC panel. It fit really clean for my car and it has plenty of room for any extra wires. If you put the switch panel in the ash tray you may have to modify it a little bit to get any excess wires to fit. Also you may want to consider how you are going to wire up the kit first before you start the install. Here is a thread i started a week or so ago just before i wired my kit up. I made a few changes to it but you will get the idea... https://ls1tech.com/forums/nitrous-oxide/418950-nx-kit-wiring-check.html
I hope it helps... Also, I found that if you look between your AC vents and radio you will see your fog lamps switch and maybe a blank slot just to the right of it. If you take off your the outer panel and you might have an extra wire harness attached to the back of that blank button. If you do, there should be a red and black wire attached to the little harness. These two wires make a great 12 volt power source, and they are ign key controlled so when the car is off the system is dead.
Good luck
Good luck
