Ampacity ratings for NX fuel & nitrous noids?
Old 01-14-2006, 03:55 PM
SmaknaSS's Avatar
Default Ampacity ratings for NX fuel & nitrous noids?
What are the ampacity rating's for NX fuel and nitrous solinoids? they are the solinoid's in this picture, What kind of currents am I looking at? I'm trying to size my wires accordingly? Thanks in advance
Old 01-15-2006, 11:50 AM
Robert56's Avatar
One of the NX guys will get to ya soon.
Robert
Old 01-15-2006, 03:24 PM
SmaknaSS's Avatar
What about the inductive kick on these solinoids? I dont see anyone putting flyback diodes/inductive quenching diodes accross the coils.
Old 01-15-2006, 03:43 PM
spanktu's Avatar
16ga. will be more than sufficient for those solenoids
sizing them by current is not necessary because they are used for short bursts
if you wanted to look at sustained current on them you would be using 10ga. most likely.
Old 01-16-2006, 06:53 PM
Nitro Dave's Nitrous Outlet's Avatar
The ice man solenoids pull 28 amps for nitrous and 3 1/2 for fuel.
Thanks
Dave
Old 01-16-2006, 07:14 PM
ITSTOCK's Avatar
I had a 16ga. wire literally melt and almost catch on fire, so for safety I put in all 10ga wire. Overkill?? Maybe, but it's extra wire laying around so it can't hurt (especially at the close to 30amps they pull).
Old 01-16-2006, 07:28 PM
spanktu's Avatar
Uuuuh how many solenoids did you have on one 16ga. wire?
and how long of a run was it?
your relay should be mounted as close to the solenoid/s as possible and it sounds like maybe your main feed wire was way too small.
maybe for specifics I should say wires from the relay to the solenoids(each)
should be 16ga.,main feed should be 12ga.
even 10ga DC will be close for sustaining 30 amps,AC you only need 12ga.
by code
Old 01-16-2006, 07:51 PM
ITSTOCK's Avatar
by code
I'm talking about the main feed wire, nothing else
Old 01-16-2006, 08:07 PM
spanktu's Avatar
that is pretty funny 16 for a main
10ga is what I would recommend for a main feed if you want overkill 8ga
Old 01-16-2006, 08:21 PM
ITSTOCK's Avatar
it wasn't so bad for the NOS noid that pulled 3 amps that's why it was there, and I didn't even think about the noid pulling 10x more amperage when I installed the iceman solenoid
Old 01-16-2006, 09:10 PM
Closed ex-Sponsor Account
NXRICKY's Avatar
Nitrous pulls 28 or so, fuel is 3.5. 12 ga.wire on any main load wires. and 18ga on control wires.
Ricky
Old 01-16-2006, 10:23 PM
mrr23's Avatar
really? 28 amps? that's kinda huge. granted, i'm used to small n2o noids pulling 5-7 amps.
Old 01-17-2006, 11:37 AM
Somebody09's Avatar
Ricky
Hmm... very good to know.
Old 01-17-2006, 05:44 PM
SmaknaSS's Avatar
Thanks
Dave
I don’t dought you, but god that seems high, I have 12 AWG so I'm thinking I should be fine for intermittent duty. With 10 AWG I can run all day long on 31.5 Amp’s, but I shouldn’t need that. Thanks for the replies, everyone.
