How are you doing your senders and pressure activated switches?
1 Post
Okay my bottle is mounted in the spare tire well for the first time. I want to come off my bottle nipple 4 AN (?) with a short braided hose to another 4 AN fitting on one side of a manafold fitted with a heater pressure switch and an electronic nitrous pressure switch. I will end up with male 4 AN nipples on both sides of the manafold and attach that to my main line from rear to front.
Is there any accessory to mount the manafold? I'd prefer not to have it dangle and vibrate. My only thought is C Clamps on either side of the manafold around the input hose and the main nitrous line. if this makes sense do you see any reason it wouldn't work...are there any machined manafolds with mount holes for surface mounting? Art work attached.
1 Post
Originally Posted by DynotuneN2O
Your using a 3an feedline??
1 Post
Originally Posted by 860 Performance
Your idea is fine, most NX kits are -4AN, not 3AN for main feed lines.
That is a nice set-up.
