Nitrous Related Wiring
#283
i need somebody to draw me up a wiring diagram please! i have a nitrous outlet wet kit with purge, nitrous outleet bottle heater, nitrous dave's 4 button switch panel with arm, purge, heater, and bottle opener buttons (dont have remote bottle opener so won't be needing that) zex tps switch, msd 8969 digital window switch, and lingenfelter lnc-001r timing retard controle. any help would be greatly appreciated thanks
#284
does anybody know how to wire in a lnc-001r launch control module?! i'm only using it for the timing retard function for my nitrous. i see the four connectors that plug between the factory harness and the coil pack connectors but i have one black wire that hangs loose and i'm not sure if it goes to a line lock, solenoids, relay, tach?
#285
Okay now I've got the lnc-001 figured out. But I've run into another issue, I'm using the zex 82108 tps switch and there are two blue wires that run off the box I'm supposed to tie each one into the negative wire off each solenoids but I don't want to ground the solenoids immediately after the tps switch recognizes wot, the lnc-001 will apply ground to terminal 85 on the relay once I hit 3,000 rpm so my question is what do I do with the two blue wires?
#286
nvm, i just realized that the solenoids aren't going to be powered until i close the circuit by providing ground to the nitrous relay that will be coming from the lnc-001 once it hits 3k rpm
#287
LS1Tech Sponsor
Lnc-001
Just to clarify, the LNC-001 (or the LNC-002, LNC-003 or LNC-2000) don't have built in external RPM switches so they can't activate or deactivate any external device. The wires to the LNC-001 are activation inputs, not outputs.
#288
Where is the white wire for the tach on my 98 c5 coupe? I have to tie in my msd window switch so under the pass side dash would be the easiest for me to get to but I've read others say u had to pull the battery and tray out and find the pin on the PCM down there but that looks to be a bitch
#289
LS1Tech Sponsor
C5 tachometer signal wire
The tachometer signal on a 1997-1998 C5 Corvette is:
LPE RPM switch instructions link.
- PCM connector C2 (Blue)
- Pin 35, white wire
- Circuit # 121
#291
big thanks to brandon@nitrousoutlet for the wiring diagram, really close to what i drew up other than i powered the zex tps off terminal 87 rather than 86 for what dumb reason idk what i was thinking lol, oh well easy fix.
#292
if you would please take the time to draw me up a diagram i would be more then happy to paypal you something for your time it took. im wanting this install to be as easy as possible since i hate wiring and always try to avoid it at all cost
my setup includes:
a custom switch panel (arm, heater, purge)
NX wet kit
NX heater
HSW microedge
Purge
WOT switch
Thanks,
Dan
my setup includes:
NX wet kit
NX heater
HSW microedge
Purge
WOT switch
Thanks,
Dan
#293
my setup includes:
NX wet kit
NX heater
HSW microedge
Purge
WOT switch
Thanks,
Dan
my setup includes:
NX wet kit
NX heater
HSW microedge
Purge
WOT switch
Thanks,
Dan
#295
i really need help with a diagram for...switch panel, hsw wet plate kit, microedge controller, wot switch, bottle heater, bottle pressure sensor!!! ive been asking a ton of people and not getting any help, really hoping to get it done tomorow started messing around with it today
#296
I'm also needing a diagram for for my system if possible. Brandon sent me a few diagrams, but I'm hoping to get a specific drawing. I will be using efilive os to pull timing and tps to activate. Thanks. My kit consist of:
Nitrous outlet(N.O.)102 plate kit
N.O. Purge
N.O. Auto billet heater
N.O. Bottle opener
N.O. Ashtray switch panel
N.O. Fuel pressure switch
N.O.S. mini
Efilive os for pulling timing
N.O. Purge
N.O. Bottle opener
N.O.S. mini
#297
Can someone point me to the wiring diagram for the following if one exists?
1) Nitrous Outlet single stage 78mm plate kit with purge
2) NOS Mini Progressive Controller P/N 15974NOS
3) LNC 2000
4) Custom Nitrous Switch Panel with N20 Arm, Purge, Heater (won't hook up until later) and Bottle Opener (won't have or hook up until later)
5) I'll also be using the Leash Single Stage Nitrous Board to help simplify the process and provide a cleaner look. http://www.leashelectronics.com/Simp...rd-SSN2012.htm
If one does not exist, could someone help me out by creating a wiring diagram?
3) LNC 2000
#300
Hey hoping you guys can help me out with this wiring stuff.
I have an emblempros cubby hole switchplate with arm button, purge momentary button, heater button
Dynotune Plate kit
Bottle heater
purge
Lingenfelter LNC-2000(too retard timing while spraying)
HSW Microedge (lockout by gear, window switch, and TPS activation,etc)
Dynotune Plate kit
Bottle heater
purge
