Any alternatives to TNT power ring?
Right now i have a tnt kit, and i didnt want to trim my lid to make the power ring fit. So i used the fernco mod for my 90mm NW TB, and it works ok but i don't really like it. Will nitro daves plate work for a tnt kit or does anyone else sale a plate system i could use? thanks!
Yes our palte conversion will work with the tNT system. So will the NOS. We carry both. You will need new solenoid fittings to replace the Ts comming out of the solenoids. Then you will use two of the feed hoses you already have from the solenoids to the plate.
Another option you can do is use the NX two piece nozzle nuts and lock the nozzles in the bellow instead of using the power ring.
Dave
Dave
Yes we have a 90mm plate kit also, in single or dual stage. Plate seperate, or as kits. You can get the single stage plate, then in the future if you decide you would like to go dual stage, just send the plate back for maching. Here's a pic, and a link. Prices for just the plate are on our new site.
90mm Nitrous Direct Plate kit info
Robert
Robert
