Which plug do you read?
I know most engines have a specific cylinder or sometimes more than one that tend to burn hotter that the others. I was just curious to know which cylinder/s run hotter on the LS1 so I could look to that plug for detonation signs.
TIA
Hummer
TIA
Hummer
Originally Posted by Mike TexaSS
You should look at all of them every time.
-Ben R.
-Ben R.
Race your car!
#7 typicially runs leaner then the rest, the back plug in the drivers side. #8 is the next worst wone, the last plug in the passnegers side.. the one you don't want to get to LOL. I'd at least look at #7, and if that doesn't look right, then start pulling the rest of them. A couple on each side would be a good idea at a minimum... but I agree with the stateent above, all of them every time would be the smartest thing to do.
being: 1,3,5,7 are on the driver's side and 2,4,6,8 are all on the passenger's side?
Originally Posted by WS6HUMMER
Thanks! So the cylinders are numbered like a second and first gen SBC
YES THEY ARE.
How are you guys pulling the plugs after a nitrous run? It's kinda hard for me because I have to drive the car somewhere to let that biach cool before I even get my hands near a hot engine. I can see it being easier at the track though since there's generally lot's of room to park the car, hang out and let it cool for awhile.
Race your car!
after a run you **** the car down and pull to the side somewhere on teh return road.. shut the car off as soon as possible. Unless you have a tow/support car that brings your car back to the pits, like an atv, or something like that. As for the hot engine bay, get used to it.
Restricted User
Agree on #7 first and always check. And if your running a wet kit pulling fuel off the rails, then stick with the drivers side primarily. I have only seen pass side go bad when there was a lot gone wrong, which it can all be seen thru the drivers bank. On a wet off the rail, the drivers side WILL go leaner, all things being equal, before any of the passenger side, to include #8.
