Nitrous Tune vs. N/A Tune
I have heard that people generally dyno low n/a on a nitrous tune than on an n/a tune. Is there a way to run both tunes on the car, but have the nitrous tune kick in when the nitrous switch is flipped?
which control boxes do that?
I just got the digital dual window switch box from you, will it do it?
NO-00-6100 Digital Dual Window Switch
Integrated wide-open-throttle detection
Each channel has a multi-gear lock-out setting
User configurable for rising or falling TPS signal
Supports low voltage tach signals as low as 3 volts
Works with irregular tach signals such as V10 and 3cyl
Push-button programming with integrated LED digital display
Dual window switch
Compact rugged, waterproof design
Dual window switch
Originally Posted by nomorews6
so can a wet kit have both tunes?
Just my 2 cents.
I'm using the Timing Tuner with a wet NX 100 shot. I've only spray it once. I am very happy with it, on motor-10.79@123.62 on the 100 shot-10.13@132.57 and thats on a 1/2 second delay. This is in very good air.
Originally Posted by WS6HUMMER
I run a Timing tuner that retards the timing 6* only when I arm the nitrous and the WOT switch is tripped. The only draw back of N/A performanced I have noticed is the loss of 2MPH in my trap speed. The only thing I can figure is that the colder plugs and smaller gap are affecting it, I also have a rich N/A AFR( 11.2) I just got HPT so hoping I can get my N/A trap back up.
Just my 2 cents.
Just my 2 cents.
can u elaborate on that?
gap?
plugs?
shot size?
thanks,
dan
gap?
plugs?
shot size?
thanks,
dan
gap?
plugs?
shot size?
thanks,
dan
Plugs NGK TR6
150 wet Jetted for 950 PSI and 60 PSI fuel pressure
This is all on a mail order tune that is not right for my current combo, AFR N/A is in the low 11's. Just got HP Tuners so I'm hoping I can get everything straightened out and lean it out to the high 12's.
Guest
Posts: n/a
not sure why you lost MPH other than being very rich...I am running TR6's gapped at .035 also and saw no difference between the TR6's and the TR-55's.
I am running a mildly agressive NA tune (13.0 A/F) and pull 3-4* of timing with an external ignition box for my NX runs.
Do your self a favor, get a wide band and fuel pressure gauge if your going to play around with nitrous .
Spend a little extra money on a wide band that is a/f settable and get rid of the fpss . It will turn off the nitrous if the a/f goes above a certain level .
I run a custom Nx efi 2 stage 150/150 , 62/28-62/22 ,,a nice kick *** n/a tune ,, i pull "0" timing but i run a stand alone 3 gallon fuel cell with torco 116 nos fuel .
Im running 21 degrees with the 408 on and off the bottle and have never seen knock retard with TR6's @ .032
I drive the car everyday to and from work and get an adverage of 17 mpg in the city and 24ish on the highway .
I can spray about 45-50 lbs of nitrous on 2 gallons of race gas with this setup
running 60 psi fuel pressure and 1100 psi nitrous pressure , 11.7 a/f .
500 rwhp all day on 93 octain and it steps up to 650 and 800 rwhp with the click of 2 switch's
