Big shots inside! 250+ Whats your setup?
What is your set up?
Mine
Motor: 427 sleeved ls2 10.5CR
Tranny: Built M6
Kit: NX Fogger four noids (high pressure)
Shot: 300 on a FJO progressive
Fuel: stand alone by nitrous outlet (high pressure)
Plugs: NGK TR8's
Timing: 18 degrees
Buttom/Switch: WOT under peddle
Mine
Tranny: Built M6
Plugs: NGK TR8's
Timing: 18 degrees
Matt
Cool, I'm looking to get info on some clutches and rear ends so I can make my car more than a roll racer
So far it looks like a textralia oz700 and midwest fab 9" rear........now I just need teh moneyz!
Race your car!
I do understand that aspect of it, but my concern was with the jets being so small on the fuel side I worry about something getting in one of them and clogging it up and then having a really bad day.
With that type of shot I'd still be flowing the fuel system to verify the pressure with it.
Matt
Matt
Motor: STP 347ci, Stock Block and Crank, Scat Rods and Diamond Pistons
Tranny: TH400
Kit: NOS NOSzle Kit
Shot: 275, all at once
Fuel: stand alone by Solid-Technology.com (low pressure)
Plugs: NGK TR8's
Timing: 16 degrees
Button/Switch: Nitro Dave's Window/WOT Switch
Tranny: TH400
Kit: NOS NOSzle Kit
Plugs: NGK TR8's
Timing: 16 degrees
I've been saying it for a while now.... there isnt much power in timing, the right A/F has alot more power than a couple degrees of timing. The problem is when you start to get the A/F close to right is when the timing will melt your ****!
Good luck to those of you running rich tune ups with alot of timing.
Run the car with 2-3 degrees out and I bet it doesnt slow down. Then leave the timing out and take some fuel away and watch it go faster.
IMO TR8's are not cold enough for a 300 shot.
I'm at a 350 shot and running NGK 11's .... hell I'd run 12's if they made them. lol
