Is the T56 in the CTS-V the same as the one
in the C5 Vettes, 6spd F bodies, GTO...etc...etc...etc...
i'm assuming the gearing might be different.. but as far as clutch and flywheel replacements.. would a clutch and flywheel for one of the above mentioned work for my V? Or do I have to get one specific to the V?
The caddy uses the new version T56 made by Tremec
EDIT: To finish answering. I am pretty sure you could get away with either vette or Fbody components. I havent seen a cutaway of the car so I dont know if it uses a torque tube like the vette since its has IRS or if it just botls to the motor with a bellhousing and off you go.
Hmm.. I don't know if this helps.. but i'll start posting pics to see if it does. =)
this is the TPIS flywheel for the CTS-V
Originally Posted by TwoFast4Lv
The CTS-V uses the same gears and Multi cone syncros as the Z06 from what I hear....but I do not know much...
BTW they are NOT interchangable!
The shifter in the V mounts to the floor,too so there are only like 2 options for aftermarket shifters. Both of which cost around $400 Just another difference.
T56 Swap Question
Thanks for the help!
