Northwest Members WA, OR, ID, MT, WY, SD, ND
Dyno results for the brute.
Old 11-09-2005, 10:25 AM
CharlieCobra03's Avatar
Default Dyno results for the brute.
Ok, took it to the Dyno yesterday and she put down 427 / 455 first pass. The guys yanked the carb, rejetted it, change the acelerator pump spring etc. and we went again. She maxed out at 437 / 460 while spinning on the Dyno. We tried changing tire pressure but still had a big wobble in the graph on all runs. Man that TH400 is eating a lot of power. They did get the A/F dead on and got rid of a nasty hesitation it had. I got a fresh pair of QTP's to put on today so maybe I can sneak back up there for another run or two. They figure she's making about 580 at the crank. Time for a manual shift valve body I guess.
Old 11-09-2005, 11:42 AM
jimbob's Avatar
Those are great results
Turbo 400 and 700r4's suck about the same in case you ever want to change out...
The hp number is more like 550 Flywheel (which is a great number for that combo)!
Was that SAE corrected? You got to watch those dyno guys, some times they forget and leave the last import correction in there....
Old 11-09-2005, 12:23 PM
Yep, SAE numbers Baby!
Old 11-09-2005, 12:32 PM
jimbob's Avatar
Little Monsters or that new place up in Marysville...I'm assuming up there means that? Carb Conns good but a little expensive....
MMMMM...HORSE POWER Gooodddd...
Old 11-09-2005, 12:45 PM
Nah, Meridian Performance MPS up in Bellingham. They did 10 runs with A/F, pulled and rejetted the carb, played with the timing and A/F for 1.5 hours. The cost? $162.00. These guys do big blocks for a living and have 6,7 and 8 second cars all over their walls. They know their ****.
Old 11-09-2005, 12:48 PM
Poik's Avatar
Got an address? Nice results, I bet that thing throws you back pretty hard.
Old 11-09-2005, 12:53 PM
Here's a link: http://wcdirectory.com/mps
It puts ya in the seat. I'm thinking about a TCI 4400 flash stall for it.
Old 11-09-2005, 02:10 PM
jimbob's Avatar
Cool...Now we have dyno jets from south to north Washingon
A 3500 "10 inch" flashed to 4500ish in my friends 439ci BB Chevelle...You might want to rethink that stall!!! Unless they can guarantee that is the stall after install on your combo.......
Old 11-09-2005, 02:26 PM
WS6freak's Avatar
Very nice numbers! What is the rpm range? Is it a flat curve?
Old 11-09-2005, 02:30 PM
00Vette's Avatar
Those are definately nice numbers...........
Old 11-09-2005, 02:36 PM
The range was from 3000 to 6000 and it was decently flat. Max TQ at 4300 and Max HP at 5700.
Old 11-09-2005, 04:12 PM
LSxChevelle's Avatar
Nice #'s!! Got any pics of your car??
Jason
Old 11-09-2005, 04:35 PM
Not yet, it's green, kinda ugly (old paint) and just doesn't look like much until it fires up.
Old 11-09-2005, 04:57 PM
Nate_Taufer's Avatar
Definitely something to think about. The tq of a BBC will most likely always flash higher than what it's rated at.
Plus I thought you wanted to spray it? If that is the case then it will stall even higher. I'd suggest a 3200-3500 n2o converter.
Nate
Old 11-09-2005, 05:05 PM
Amorget's Avatar
MPS is a good place. Into Stangs, but it runs 8s (as I recall) up at Mission, and they are nice guys overall. Dynoed my 2000 up there.
Old 11-09-2005, 05:20 PM
NVME88GT's Avatar
I hear they do nitrous fills pretty cheap.
Old 11-09-2005, 05:52 PM
Forest Green??
Old 11-10-2005, 07:21 AM
WAHUSKER's Avatar
Great numbers, especially considering how much driveline loss you have. Not to argue with Jimbob, but I'm with them at 580. You gotta be losing 25% with that setup, which works out to multiplying the rwhp # by 1.33 to get crank #s. Either way, it's gotta be fun to drive. Congrats Charlie...can't wait to see that thing in person.
Old 11-10-2005, 09:30 AM
Thanks guys. Forest green? Hell, I don't know. It's between medium and dark green. I put the stickies on her yesterday and she flat hooks after a bit of heat. It's not strong enough to suit me yet but I reckon that 871 would cure that. More power can come later after I tweak what I've got.
Old 11-10-2005, 11:14 AM
jimbob's Avatar
I bet you tell that to all the young girls.......perve....
Quick Reply: Dyno results for the brute.
