Old 05-10-2016, 02:18 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Exterior Guides
Print Wikipost
which Type/Brand of Paint for CETA mod?
Old 08-31-2009, 04:26 AM
pheer's Avatar
Default which Type/Brand of Paint for CETA mod?
im loving the look of the CETA mod and i'm definitely going to do it but, i can't find any real info on any particular paint and/or primer to use or NOT to use....
i did search and only came up with something along the lines of "sem" paint?
any info is greatly appreciated...
Old 08-31-2009, 05:36 PM
stroked383HSR's Avatar
here you go....it may be in here.
https://ls1tech.com/forums/paint-bod...umper-how.html
Old 08-31-2009, 10:42 PM
colby72olds's Avatar
I used dupli color, December will be 2 years ago and it still looks great.
Old 09-01-2009, 06:02 PM
pheer's Avatar
did you use the high temp stuff?
i checked in the howto and didnt find anything, thats why i made this post....though there is a big possibility i overlooked the information...
Old 09-01-2009, 06:30 PM
Ws6Wicked's Avatar
pay $150 and have a paint shop do it,
Old 09-02-2009, 07:34 AM
2000pewterN20's Avatar
i used duplicolor primer and duplicolor acrylic enamel semigloss black. i started with acrylic lacquer but i couldnt get an even finish. enamel did the trick tho! oriellys had a sale, buy one can get one free
Old 09-02-2009, 04:44 PM
cvalliere's Avatar
I still don't understand why everyone uses primer, there is no need, it's not like it's some kind of magical adheision promoter. All you need is a red scotchbrite and some black spraybomb.
Old 09-02-2009, 05:54 PM
it does help adhesion if you use a self etching primer.
also, if you use a lacquer, then you need to use a primer sealer.
Old 09-02-2009, 10:38 PM
cvalliere's Avatar
I don't know of 1 aerosol primer that is not lacquer based. And why would you use a self etching primer over top an already clearcoated surface, let alone bare plastic (if you happen to have bare plastic). A simple scuff with a "red" scotch brite and wipe down with a precleaner are completely sufficient enough.
