about how much to replace quarter panel
Old 04-19-2010, 08:12 AM
jccz28's Avatar
Default about how much to replace quarter panel
what should i expect to pay roughly getting one replaced on my 98 z28
Old 04-19-2010, 08:48 AM
pancho toco loco's Avatar
Labor only on replacing the panel $600-$800 pending location a shop. Thats only labor for replacement, no paint or parts.....
Old 04-19-2010, 11:58 AM
crimson_bird's Avatar
are you talking about the rear? cause thats not something like the front fenders that you ca just replace easily. if an area needs to be fixed in the rear, it has to be completely cut out, and replaced with a section out from a donar car, since the whole rear section of the car (minus the bumper) is all one piece.
won't be cheap. hopefully it can be repaired and not need to be replaced
Old 04-20-2010, 11:45 PM
Sawzall and Welder Mod
Whistler's Avatar
It also depends on how far in the damage goes. Often some of the inner panels need replacing or straightening.
Old 04-21-2010, 12:21 AM
bww3588's Avatar
it has inner structure to it, as a whole, yes it is part of the entire rear end, but if you have a spot weld cutter, you can just replace one quarter pannel, but let me warn you, there is a metric **** ton of spot welds holding that panel in.
Old 04-24-2010, 03:56 PM
KTK Z28's Avatar
I'm an auto body tech, replacing a quarter on these cars ... Basically whatever amount your thinking multiply it by 2 and it still will likely not be enough. Quarter replacements on any car is difficult, on these cars it's even more so because of the amount of spot welds and the fact that the sail panel band is glued on...
Old 04-26-2010, 10:37 PM
krwyellowZ28's Avatar
1/4 replacement on these cars isn't bad to do yourself with moderate novice skills. I've done several cab corner replacements to repair rust, and this was my first 1/4 skin... really not that bad at all, just time consuming... and a **** ton of spot welds like mentioned before.
Attached Thumbnails about how much to replace quarter panel-0316091820.jpg   about how much to replace quarter panel-0424001356a.jpg   about how much to replace quarter panel-0426002019.jpg
Old 04-27-2010, 10:28 AM
black_sheep454's Avatar
That's the easier way to do it by splicing it around the sail panel.
Quick Reply: about how much to replace quarter panel
