Making Bumpstops and 315s Work
I know there are plenty of threads where people have done the BFH mod to fit 315s. I haven't had to do much, but unfortunately when my car is on a lift, the insides of the rear wheels get hung up on the bumpstops. I've seen that most people just cut them out, but I think Pennsylvania State Inspection requires them to be there and functional.
Anyone have ideas on how to eliminate this, yet still keep the bumpstops? I'm not getting rid of the 315s.
(Sorry if this isn't the right section. Seems like bodywork to me.)
Offset a little biased inside? Spacer help?
Unfortunately only lifting from the axle isn't an option. Lifts will cause the same problem.
Look up Rampant....he did it right.
https://ls1tech.com/forums/wheels-ti...stop-tabs.html
I mainly don't want to scrape up my wheels. They look new on the inside and out. They actually sit flush with the fender, and stick out a tiny bit on the driver's side. I'll probably get an adjustable PHB and see if centering up the rear helps at all. It seems to want to catch on the passenger side of the car. If that doesn't provide clearance, I'll be finding someone with a welder who can set them in farther like Rampant did.
You can move the bumpstops inward a bit. I machined up some relocation brackets that moved them inward and down since the torque arm mount was banging the tunnel and put a hole in it. New strange double adjustable shocks also helped. I will look for the pics tonight and post them up. It may not work for you. I am running 275/65/15, but moved my rims inward 1" to eliminate crap getting thrown in the quarters.
I've seen a thread here where the person installed the bumpstops on the flat part of the rear end facing upwards. I've been running 315's for about 8 months without bumpstops and I can tell you that my tires will bottom out on my rolled fenders before the rear end hits the frame.
That looks really clean BlackDuk. I like that a lot.
xny 1989, I was thinking about that too. Figured something would work mounted on the axle facing up. I really need to roll my fenders too before they cut up my nice tires.
I will look up a pic, but have any of you looked into a single center bumpstop that stops on the pumpkin? I cannot remember what car was like that. I haven't been under my car yet this year to look if that is an option, but I think that you could make a drop down bracket and mount it.
I think that 90's Blazers had long bump stops, maybe make a plate and mount them in your coil springs like some off-road trucks:
Something like this would be more ideal:
https://ls1tech.com/forums/suspensio...-bumpstop.html
Although I still prefer to have the stock bumpstops and just jack the rear of the car up by the pumpkin...
Yeah, I get what you mean. I have an anti roll bar bolted to the bottom of the car and welded to the rear end, so I don't really worry about the body rolling from side to side.
What you are showing in that link looks just like the last pic that I posted, I think that would work nicely. I also prefer them in stock locations, or moved inward a bit like mine which is basically the same deal. I will be changing mine up though, my rear is already narrowed 3" per side, and I will be mini tubbing it, but I will have bump stops for sure.
To the OP, are you having issues with the axle hitting the frame? I've never heard of a vehicle inspection where they check the factory bump stops...
Your sig says you have 315s in the rear, is that correct?
Do you have your fenders rolled?
I semi-rolled my rear fenders (did not want to roll them flat for fear of paint cracking and losing structural rigidity in the fender, Ive heard they can get wavy if you get to aggressive) and still have to run bumpstops (trimmed down a little) or my tires will hit the fenders. Before I rolled them my tires would make contact with the fenders on big bumps or dips.
Here are clearance pics of after I rolled the fenders, with my shocks and springs removed so the car is just sitting on the rear bumpstops. Then take into consideration that is NOT technically fully compressed because the stops will compress more under a hard hit, this is just static weight of the car. I couldn't fit my pinky finger between the fender and the tire.
EDIT: Also as a note my car has a fays2 watts link, so the axle is sitting even on both sides, no rubbing side-to-side like with a PHB.
I just don't want to take any chances. Obviously they were integrated into the design of the car for a reason.
Seriously?
Did not roll my fenders.
I may have bottomed out before or maybe the axle hit the car, but man I never feel or hear it. Might have happened. Theres no visible contact spots anywhere.
Maybe I should go to the junkyard and get some bumpstops and cut them down some and put them back in....just in case....lol.
I need to do this and great job with the fabrication/machining on those brackets! I ground down the polys and factory mount as you did and there close but rather fab something up and not worry about it.
Iv'e bottomed out my car over 100 times for sure, theres this one road that goes down like a roller coaster where I live and you hit 80 in a 35 real quick. When you hit the bottom it launches like a rocket and the back end slams not hits slams. lol. Guess it's 35 for a reason.
Yes, I have 315's...since 2002. And I'mn lowered on G2 Super Springs quite a bit.
What wheels do you have and do they tuck up under the fender at all or are they pretty flush with it?
On that same note then did you have to do the BFH mod to the inner fenders so the 315s wouldn't rub there?
Got any close up pics of your rear ride height? This is interesting...
I just my 315s on my widened ws6 wheels and the bumpstops are into the wheel about 1 inch maybe 3/4. So I can't grind any way bc it's not close.
Anyone else run no bumpstops?
I did long ago but the factory doesn't weld the nuts in the same place so the holes would be different for all cars...... but they could be slotted for a universal fit. There wouldn't be any profit in it. I used to go to the junkyard a lot and if I saw really nice bumpstops, I always purchased them and put them in a shelf. I did notice that a set that I pulled off an 80s f body was almost 1/2" taller. Not sure if they were replaced or still one though.
