A couple simple tuning questions...
Old 02-04-2009, 02:27 PM
RickyMartinZ28's Avatar
Question A couple simple tuning questions...
First, how do I figure my A/F ratio without a wideband... I know it won't be perfect, but it'll get me somewhere close, and right now thats what I need.
Second, on DCFC, what do I modify, or what values should I modify, to make my throttle response on decel a little more aggressive. It'll rev up quick, but it takes a second to come back down...etc...
Thanks...
-Rick
BTW, I'm using TunerCat
Old 02-04-2009, 02:42 PM
LS1TECH Sponsor
foff667's Avatar
over 450mv means you are richer than 14.7:1
under 450mv means you are leaner than 14.7:1
Old 02-04-2009, 03:29 PM
Is there an equation to figure that? Say it reads 478mv, could I figure what the AF is from that?
Old 02-04-2009, 04:37 PM
LS1TECH Sponsor
foff667's Avatar
That is pretty much the equation. There is no true relationship mv=afr thats why anyone seriously into tuning has a wideband o2 sensor in their toolbox
Old 02-05-2009, 08:29 AM
YellowToy/A's Avatar
If you tune get a wide band. If you dont want to tune right get some else who does. Why do u want to decel fast? It will cause ur engine to stall if you do not do other things.
Old 02-05-2009, 08:51 AM
samh_08's Avatar
I know what he means about wanting it to rev down quicker. Coming from a old school carb setup, that quick throttle response both up and down sound great and make it sound like its finely tuned.
Anyone have some tips on how to do that?
Old 02-05-2009, 10:27 AM
Well right now it takes what i think is excessively long on decel. Sounds like a bmw coming down....
As long as you blend well, I don't see where stalling would be an issue...
Also at WOT, my MV stay real close to 900mv... Is that normal or does that seem excessively high?
Old 02-05-2009, 12:58 PM
rnl35thss's Avatar
WOT should go into PE and ignore O2s.
Old 02-05-2009, 01:04 PM
Frost's Avatar
Getting the revs down is an airflow issue; get rid of the airflow and you get rid of the issue.
As has already been mentioned, what the NBs do at WOT is go high, if you need to know/see/adjust AFR at WOT, you use a wideband.
Old 02-05-2009, 01:24 PM
I'm gonna have to invest in a dang Wideband I suppose... Thats cool.
I've done a ton of research today, I'm learning some good information...
Thanks
-Rick
