Hptuners help! A4 to t56 tune
Old 03-25-2009, 09:36 PM
nerisls1z's Avatar
Unhappy Hptuners help! A4 to t56 tune
ok done swapping my a4 out of my 98 z28 for a 98 t56 only other mods lid 8.5 wires thats it for now trying to change speedo to work right need info on how to with hptuners...car has stock 10 bolt with 2.73's not sure if i flash the pcm right with a manual tune still saying auto trans 4l60e cant figure this could somebody help please
Old 03-26-2009, 04:13 PM
jmm98LS1's Avatar
Wow that's a SUPER tall gear to run behind a t56.......I ran the 3.23's for a few weeks and they sucked, I can't imagine 2.73's.
When I did my swap, I just did a "write entire" with a '98 M6 file and everything worked fine. To adjust your speedometer, divide your tire height by 2.73 to find the correct ratio.
Old 03-26-2009, 04:17 PM
Trunion King
bene's Avatar
Good to know. I'm about to do this conversion too. I've copied 02 M6 LS1 hoping I can just copy the file to my tune.
Old 03-26-2009, 07:55 PM
2manytoys's Avatar
I never could get a "write entire" to work on my PCM. HPT has a walkthrough of how to program your gears on a 98 to make the speedo correct.
Old 03-26-2009, 08:25 PM
nerisls1z's Avatar
it doesnt seem to bad i do alot of highway running so that dosent bother to much just the dam speedo so i just divide the tire hieght with 2.73 thanks another thing is i wrote entire but still getting codes but still a rookie with hpt
Old 03-26-2009, 08:59 PM
nerisls1z's Avatar
jmm98 i tryied to do that an still its way off i have 245/50r16's which to the hpt unit converter is 25.6/ that by 2.73 is 9.38 and it still off am i still doing something wrong here
Old 03-26-2009, 09:20 PM
nerisls1z's Avatar
that sucks you blew the cable to the obo port or to the interface ...cable not to sure but hpt for the interface
Old 03-26-2009, 09:26 PM
Gingervitis Addict
slow67's Avatar
Don't forget the A4s have a 40 tooth reluctor wheel and the T56 has a 17 tooth reluctor.
Old 03-26-2009, 09:45 PM
Trunion King
bene's Avatar
I apologized I posted in your thread but yeah.
Old 03-26-2009, 11:47 PM
nerisls1z's Avatar
so if the a4 has a 40 and a t56 has 17 how do i factor that in on hpt if you know by any chance
Old 03-27-2009, 08:42 AM
Gingervitis Addict
slow67's Avatar
Here is a screenshots
My A4 with 3.73 gears and my old T56 with 3.42 gears
Attached Thumbnails Hptuners help! A4 to t56 tune-a4.jpg   Hptuners help! A4 to t56 tune-t56.jpg
Old 03-27-2009, 08:48 AM
2manytoys's Avatar
Here is a link to the how to demo's http://www.hptuners.com/forum/showthread.php?t=5058
scroll down and look for the "Gear Change for 98 LS1 Fbodies". This will walk you through how to get it corrected.
Old 03-27-2009, 09:01 AM
nerisls1z's Avatar
ok im going to try this and see what happens thanks for the help i really apreciate the links and everything
Old 03-27-2009, 10:05 AM
9000th01ss's Avatar
You didn't do a gear change or tire size change
You did a transmission change
You need to change the VSS pulses per Rev-Trans from 40 to 17
Actually you need to do it right and get a stock M6 tune and do a write entire. Then change your gear ratio.
Old 03-27-2009, 10:29 AM
nerisls1z's Avatar
if i did everything right from what i have been reading i dont have to shift out of first till about 60mph which is great for me thank you so much
Old 03-27-2009, 10:42 AM
nerisls1z's Avatar
actually i did a m6 tune but didnt figure out the reluctor crap but thanks to the wonderful people on ls1 tech and hptuners
Old 03-27-2009, 10:49 AM
9000th01ss's Avatar
do you plan to complete that sentence or did you lose you train of thought?
Old 03-27-2009, 02:20 PM
2manytoys's Avatar
I think he is saying Thanks!
Old 03-28-2009, 06:44 PM
nerisls1z's Avatar
no i mean thanks alot for the help guys everything turned out great sorry about that lot off things going on at once
Old 03-28-2009, 07:55 PM
9000th01ss's Avatar
Oh ok lol, glad you got it worked out.
Quick Reply: Hptuners help! A4 to t56 tune
