Timing at max tourqe vs timing at max hp?
So i heard that you are supposed to have different timing at peak tourqe than at peak hp.I heard that you should have the least amount of timing at peak tourqe and then ramp it up after that point.If this is true where would peak tourqe be roughly on a stock lt1 with 8lbs of turbo? I am currently running 18 degrees from 2,000 all the way up at 100 kpa. It does feel slouchy up top. Any opinions on changing it up a little to broaden my tourqe curve or just get more power?
It isn't a hard and fast rule, but setting your timing according to cylinder pressure is a good rule of thumb to avoid detonation.
Your torque curve indirectly represents cylinder pressure.
Your peak torque on a turbo can be a moving target if you have a laggy turbo. If you have a small turbo that spools at a reasonable rpm (ie 3k ish) then your torque curve will look alot like your NA torque curve albeit just a lot higher.
The best way to set your timing according to torque is to get the thing on a dyno. Your lowest timing will be around peak torque. Try adding a couple degrees up top after it has passed peak torque to get the most out of it. I wouldn't go more then a few degrees. Ie maybe 18 through peak torqe (ie 4500) and ramp to 20 by max RPM (ie 6200).
FWIW alot of folks run fixed timing and it works just fine.
LS1 Timing
If you advance the timing on the LS1 engine with the LS1 Timing Tuner box, should the idle go up a little??? Then also if I retard the timing should the engine idle slow down?? is this the way it should work, since this is what I noticed but just worried the tuner box is not right???
Idle speed is the result of torque appplied to the crank, increasing the timing as a base will serve to increase immediate torque output and the result should be an increase in engine speed, however your PCM should be countering with IAC steps that since the desired idle speed would be higher than commanded.. never actually tried it myself though heh
Wtf??
VTC_WS6 ls1 timing
Okay... The external module that I used is the LS1 Timing Tuner that plugs into my crakshaft sensor... so from youR reply it sounds like I programmed it correctly, I set the timing a few degrees advance under non-N20 activation and then it will retard the timing a little after my N2O goes active..... THANKS..
