Throwing codes and dying. KR is scary, too. log inside
Old 05-16-2009, 10:07 PM
UnZFeat'd's Avatar
Default Throwing codes and dying. KR is scary, too. log inside
Im throwing a P0103 for high voltage MAF, P0704 for clutch switch, P0122 for TPS sensor, P0405 for EGR valve... Also throwing a B1001 code, which i cant seem to find what its for. MY car sputters up towards higher RPMs and sort of dies out, not shuts off, just hesitates a lot towards higher RPMs. Here is a log of what happened. Thanks
File Type: hpl
Old 05-17-2009, 05:41 PM
UnZFeat'd's Avatar
come on guys, can anyone help me out here? I really think something must be wrong. Like knock sensor or something?
Old 05-17-2009, 07:04 PM
69LT1Bird's Avatar
http://gearchatter.com
Old 05-18-2009, 01:29 PM
UnZFeat'd's Avatar
Has anyone had the chance to check out my log? I think theres a little something more than the error codes it is throwing.
Old 05-18-2009, 01:39 PM
69LT1Bird's Avatar
Post your tune
Old 05-18-2009, 02:20 PM
UnZFeat'd's Avatar
i posted a log of how it drove at WOT, you can see the KR spike, which worries me, because i just filled my bottle up and s=have yet to spray it, so it couldnt be because of spray.
Old 05-18-2009, 02:23 PM
69LT1Bird's Avatar
If you want help, post the tune also, the log is all fine and dandy but the tune could also be causing the issues, without both you are one your own.
Old 05-18-2009, 03:32 PM
Frost's Avatar
Did you use a beta for that log?
Old 05-19-2009, 05:11 PM
UnZFeat'd's Avatar
i used the tune that you gave me a while ago. Would it have changed when i uploaded it to my car? What does the beta mean? Thanks guys
