wideband sensor getting to HOT?
I'm noticing after an hour of logging and making changes that my LM1 is going way lean(19-20AF) at idle, when I start the logging process when everything is cool(but up to coolant temp of 200f) my idle after is perfect 14.3-14.6.
Once the WB is hot, the af creeps up. When I start moving I get more realistic af values but once I stop for a traffic light the af slowly creeps up from my near perfect numbers.
WB is in the I pipe.
From my searching on here I have found others with the same problem but really no luck in fabbing up a heatsink.
My car has Long tube headers, off road ypipe and an airlid so I won't think I'd have this many problems.
Any suggestions.
Any suggestions.
Moderator
I see IAT leaning out my idle mixture too, been in
open loop SD mode for a while now tweaking every
other weekend. IAT gets heated differently than
the real air temp, by engine bay heat conduction,
but that's about all you can say.
