Predator tuners help and questions
Ok first off I read and read again the predator tuning sticky and all possible links. Ok my question is according to non WOT LTFT's. I have a couple days of established so far and my LTFT is reading +23-25%. In the tuning section I read that I need I need to adjust my injector slope to add fuel to level out my LTFT? I am nowhere near 0-2% I read it is supposed to be. After I get the non WOT fueling better I can work on the WOT. Also if it means anything my o2 readings are reading between 720 and 830. This I think means I am lean which probably explains the +25% LTFT. If I need to be more clear please let me know and thanks for the help.
Is your car modded enough to where the fuel trims being that far off (without the proper tune) would make sense?
Otherwise an exhaust leak would make sense. Your O2s might be seeing fresh air from an exhaust leak which tells the computer (falsely) that you're running lean which would cause it to add a bunch of fuel (+25 is kinda a lot). I think my car will throw a code if either bank is +/- 15.
If your O2 sensors are reading .720-.830 at WOT you could be way lean (again unless you have an exhaust leak where the fresh air is hitting your O2s). You should probably stop going WOT until you get your trims in check 1st, or get a wideband hooked up and try to figure out what is actually going on.
You CAN get a car tuned decent-ish with a predator and narrowband O2s.
Are you reading STFT or LTFT? the big sweep in numbers sounds like STFT's...
Take another look as on my older diablo the stft and ltft are right next to each other for both banks.
LS1Tech Sponsor
If so, make a nice cruise log and post it up on our forums, we'll get it figured out.
Ok checked for exhaust leaks and couldn't find any. Had a manifold crack recently while putting new o2's in. That problem is fixed tho. There is one spot in the back that I can see carbon on the outside of the pipe, but it is where the pipe goes over the panhard. It had a few miles on the clock so I figured I'd get new o2's just to rule that out. One thing I was thinking is that with the predator tune that comes with the predator could it be that it is designed for 28# inj? I know mine has 26's. If it was tuned for 28's that would create a lean condition correct?
OK thanks. I have the one that can do the real time data, but I don't know if it can log. It can do the cot and air and egr and rear o2 delete.
LS1Tech Sponsor
ok, well if you are able to disable all those codes, then it's not a new version, so no - you can't save data logs...
but yeah, with ltft's being THAT high, there's gotta be leaks somewhere... intake, vacuum, exhaust...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Ok actually found a leak at the tube that goes into the side of the TB. Fixed that and believe it or not I never noticed how rough it idled until I fixed it. Anyway can I send my unit in or can I use the pc connect to upgrade my unit. Oh and thanks a lot for your help.
LS1Tech Sponsor
a-HA!! cool!! found the problem... nice!!
yeah, you would have to send it to diablosport, and pay to get it upgraded to the newer version, so that you could save logs, do the internet updates, etc etc...
__________________
LS1Tech Sponsor
__________________
