So my local shop ....
Alright this isn't a how to kind of thing, so I don't know if its in the right place I just want to see if I am getting bent over or what.
I already have HPTuners Pro. My local shop says they will MAF tune my car for $350 not to bad but to do SD which is what I have it set up for they want to charge me $600 plus keep the car 3-5 days, the guy said anyone doing SD just on the dyno dont know what they are doing.
Whats your input on that. The price seems steep to me and I know the car needs to be driven to be put in different modes but I have never read a thread of any other shop keeping a car to do it, plus he said I would have to have it re-tuned 2 times a year when it gets cold and when it warms back up and that when the weather changes it will run bad, like more humidity and stuff ...
Your opinions please?
Moderator
Unless it is a dyno that can hold a load-point, it's
not very much use for general airflow accuracy
work. I can see needing to have the car for a
while, especially if you have to "road dyno" it.
Seems like a lot of dough for things you could go
at, a couple of hours a weekend, and get done.
Plus being familiar with it will make the seasonal
tweaks that much less a problem.
LS1Tech Sponsor
$500-600 is about right for a really good SD tune. I like to have the car for two days so I can get enough cold start data. It is nice to have the vehicle there for a broad range of coolant and air temps also. If it is tuned correctly and the coolant and air temp correction is takin care of you should never have to bring it back. Should run great all year long after a proper SD tune.
Thanks for the info, keep them coming.
I talked to the guy a few min ago he said he would do $500 cus it has a small cam and a little turbo, and it should only take about 3 days which isn't a big deal to me cus I don't drive the car during the week anyway. I am a little worried about getting a start up tune though, I want to be sure nothing is leaking before I take it to him and waste anyone's time or money.
You already own hptuners pro, buy an ngk wideband and tune the thing yourself. If he tunes it in open loop SD I could see it needing to be retuned for weather possibly as its not easy to tune the cylinder charge temperature tables. If its put in Closed loop SD and your o2 sensors work correctly you will be fine.
I already have a wideband too o2s work just fine too. Just to scared to jump on it myself being the stock bottom end and all .. And I really haven't been able to get anyone to tell me how to change me OS from the factory one to a SD one, dont know if I have to buy that or what.
LS1Tech Sponsor
Some people just don't want to tune there own car,expecially the ignitial tune on a turbo car.
We charge $600 for a 2 bar SD tune and want the car for 2-3 days too. Street tuning all part throttle tables is better than doing it on a load dyno( we own a load dyno)
Alright, so what do I need to click and change in my factory tune to get it flashed for SD and get it to start up?
I know it is a different OS and I know I will need to scale the injectors .. what do I have to do to change OS?
That just made me laugh.
The hesitance people have in doing their own tuning makes me laugh. So what if it's a turbo car. Would you remain a virgin just because your first timer was a supermodel? The worst that can happen is a premature blow-up, in which case you learn what to different the next time.
Your best bet would be to spend a good amount of time on HPTuners forum, learn, learn and learn some more. $500-600 to do a SD tune with a turbo, if that includes the license is good, takes a LOT of time.
Need to be pointed in the right direction .. see above
