HP Tuner Vs. EFI Live
I have a 99 ta and my buddy has a 02 camaro, we are thinking about going halves on a tuner, which would work better HP Tuner or EFI Live? his as been tuned before with just cam install, hes having a few problems and i have heads/cam, 92mm intake/tb, 42# injectors with no tune. im running stock injectors right now because its not tuned. Which one of these tuners is going to work better, which one is easier?
are they hard to use? i dont know much about tuning, i was just going to take my car to a dyno and have them do it, but theres only one place around my area that can and their shop isnt opening until mid april
I switched from EFILive to HPTuners recently. HPT has a much more active forum and support staff that helps out. Plus almost all the "learn to tune" books, DVDs, live seminars, and other information is HPTuners based.
My tune is 1000% better since I switched to HPTuners, although I did purchase extra "learn to tune" books to aid me in learning quickly. There is a fairly steep learning curve for any tuning, dont think its going to work like a handheld tuner where you click a few buttons and go....
baddbird99, I bought EFI Live V1 because it has a stand alone black box for data logging. It was only $250 for that black box and software. Believe me when I tell you it is very convenient to simply connect the cable and bb rather than a laptop every time I want to check things out. I later purchased the tuning portion of the suite for an additional $300. What I'm trying to impress upon you is to do the research and concentrate on the differences because there are so many similarities.
The real time tuning of HPtuners is a cool feature too, with EFILive I had to buy $600ish in Moates extra hardware/software.
Thanks guys, sounds like HP Tuner is a better option, im going to do a little more research. Will this eliminate my need for dyno tuning? We both plan on hitting a dyno eventually to fine tune our tune, but in the mean time i need a tune period and he needs to adjust his a little more.
I'm not referring to Roadrunner real time tuning. As far as I can see, HP Tuners does not have a stand alone black box like the V1. Can you point us to that feature on their web site? I've been looking but cannot find it. Also, I don't understand what you mean about setting it up. With EFI Live V1, it is a feature of the hardware cable and you simply press a button to start recording data. I must have missed something so what is the equivalent with HP Tuners?
I have had HPtuners for about 4 yrs. Recently I upgraded my Vette to the 2Bar SD tune. The Real Time Tuning is such a nice feature. I had my RAF table done in 15 mins. VE table took alittle longer, but I had a buddy drive while I adjusted the VE table. My AFR is a consistant 14.6-14.8 when cruising.
So another +1 for HPtuners and the HPtuners forum is nice. The tune repository and help section makes things a breeze.
I dont see it on their site, but here is a thread talking about it, and their "how to" setup stand alone logging.
http://www.hptuners.com/forum/showth...dalone+logging
http://www.hptuners.com/help/demos/s...onelogging.swf
But good to know.
The EFILive standalone black box datalogging is a very nice feature so you don't have to lug a laptop around when driving, and especially nice at the track, where most tracks don't allow laptops when racing. They also have the serial (digital) cable option to connect the WB directly to the BBL. Hopefully they will bring the black box tuning option out shortly as well.
OP - Do your research and make an informed decision. Either software can get the desired results your are looking for, so usually it comes down to personal preference.
p.s. They type of threads usually get locked here. I'm surprised it went on for this long.
I do wish I could afford to examine both HP Tuners and EFI Live so I'm hoping the thread doesn't get locked and I can get the knowledge of this experience from other posters.
If he doesnt know that EFILive and HPTuners for the most part do the same thing, then he shouldnt be tuning on his own. It comes down to selecting what one is more suited to you, and for me the extra help avaliable has made it worth while for the switch to HPTuners. I still use EFILive too because I can take what Ive learned using HPTuners and apply it to EFILive.
thats nice to know but i dont think that will help OP at all.
the way i see it, is they both do the EXACT same thing if you know how,what, and why to tune then you should be good going wither way.
in the end they do the same thing, but i would suggest downloading efi live and hptuners (not sure about hp tuners) software to "mess around" with befire you purchase any one.
