HP Tuners Unable to Locate VCM
Old 04-11-2010, 03:20 PM
Denali08's Avatar
Default HP Tuners Unable to Locate VCM
Here is the message:
"Unable to locate VCM, verify cable is connected and key is in the run position."
I am trying to pull the tune file from 2003 Chevy Truck. Was able to connect before. Truck was tuned by a shop using EFI Live (MAF Tune).
Recently changed my laptop and downloaded Hp TunerS from web site Ver2.22 and downloaded the driver file from HP Tuners' CD which is almost 2 years old.
Engine is out of the truck. Connected battery and removed fuel pump fuse. Key is in run position and cable connect.
What to do?
Old 04-11-2010, 04:49 PM
LS1TECH Sponsor
foff667's Avatar
Connect MPVI usb interface to the vehicles obd2 port but NOT your laptop does the green power light illuminate? If not its likely a blown obd2 port fuse.
Old 04-11-2010, 08:48 PM
repo's Avatar
I had a simular problem it was the drivers were incorrect. I got a new windows 7 and they have a diferent driver than previous systems. Good luck
james
Old 04-12-2010, 04:47 PM
Denali08's Avatar
james
Which driver did you install? HP Tuners CD driver or HP Tuners driver downloaded from their web site?
I used the driver from the CD which I think is older than the one on the site.
I will download driver from site and go back to the shop and try to test without laptop as suggested by foff667 then with new driver installed.
Old 04-12-2010, 05:19 PM
06X6spdGTO's Avatar
okay this may sound stupid, but sometimes simple things are the problem.
Did you connect VCM Scanner and forget to disconnect and close current log file??
Old 04-12-2010, 06:25 PM
repo's Avatar
we used the one from the websight. there is some updated drivers in the forum section
Old 04-12-2010, 10:01 PM
Pulse_GTO's Avatar
LS1Tech 10 Year
Check the cigarette lighter fuse.
Old 04-12-2010, 11:41 PM
Denali08's Avatar
No. Only VCM editor was open.
Old 04-14-2010, 08:23 AM
diablotruck's Avatar
When mine did that it was the cig lighter fuse under the hood that was bad.
Old 04-14-2010, 08:41 AM
Denali08's Avatar
How is it related?
Old 04-14-2010, 11:18 AM
LS1TECH Sponsor
foff667's Avatar
it powers the obd2 port.
Old 04-14-2010, 11:55 AM
Denali08's Avatar
I think it is. I couldn't charge my mobile last time from cig lighter. Had to use the other aux power outlet for charging!
I will check next time I go to the shop.
Quick Reply: HP Tuners Unable to Locate VCM
