vats questions, searched and searched....
okay, just need a final answer.....searched and searched and came up with so much info its crazy!!!
car will not start sometimes, its just random.....6 spd car, changed the switch out on the pedal already as well as the ignition switch awhile back.
so put the key in turn it over and nothing....security light will blink at the one second rate...does not stay on or lock out for 3 mintues....
also the big thing is i can roll the car, pop the clutch and drive, it will not die after starting it???
vats bypass with resistors?
new cylinder?
what??
thanks in advance!!!
new cylinder?
what??
i had the exact same problem with my car it was the vein of my existence for 2 years i hated and it only gets worse. the way i fixed it is find out what resistance is on your key and go buy a resister from radioshack and there is a plug under the dash that goes to the BCM bend the resister to a u shape and plug it in to the plug leave unpluged and tape it out of the way never ever happened again knock on wood....
kinda what i was thinking after doing all the research....it will bump start everytime and stay running.....
could it be the key cylinder and not affect the vats???
or maybe as simple as the starter, just hate to replace that if its not the problem, easy to do but money!!!!
thanks, keep em coming!!!
