ABS INOP, Brake Light, Service Vehicle Lights
Old 06-14-2010, 08:35 PM
mac62989's Avatar
Default ABS INOP, Brake Light, Service Vehicle Lights
The last two days all 3 of these lights are showing up on my dashboard. My WS6 has 68,000 miles on the clock and is running fine. Any idea what could be throwing these codes? The ABS and brake light use to come on my Camaro after putting on bigger wheels and different tires. Everything is stock but a catback. Should I be concerned and go have it scanned? Thanks in advance.
Old 06-24-2010, 02:19 PM
blackened's Avatar
Mine's been doing this intermittently as well. Would like to know possible solutions.
Thanks,
J
Old 06-24-2010, 02:47 PM
mac62989's Avatar
It's strange because driveability is normal. I checked the brake fluid and its fine. Dont get it. I reset the ABS fuses and it was good for like 5 mintues and the lights came right back on.
Old 06-24-2010, 05:05 PM
BlueMagicSS's Avatar
Check your ABS Sensors. They could be loose, shorted wiring or sensors could be bad.
Old 06-27-2010, 02:10 PM
mac62989's Avatar
^ABS sensors that are on each wheel? By digging up some old threads some guys say the problem was the ABS module was shot, others just had a loose connection in the rear housing, and others changed the sensors on each wheel. I really just want to get it scanned instead of spending money taking chances changing random things.
Old 06-27-2010, 05:34 PM
At least check them out and make sure the bolts aren't loose, that would cause an improper reading in the ABS module. But you could get it scanned and see what the issue is that way. But without a scanner a visual is the best way to rule out a few things. It COULD be the module as well. I'm not sure.
Old 06-27-2010, 07:23 PM
mac62989's Avatar
Alright I have to rotate my tires anyway so I'll check them out tommorrow while the rims are off.
Old 06-27-2010, 07:39 PM
barnat's Avatar
If you find out its your ABS box itself ?Let me know, because im going to be pulling mine to install a ABS delete kit so i can adjust my rear brakes and make some more room in my engine bay. Its got 38K on the car if intrested
Old 06-27-2010, 08:11 PM
mac62989's Avatar
^I will. I would be looking for a used one if that needs to be replaced. If its not the sensors on the wheels I'll be looking to get it scanned this week so ill know the problem soon enough.
