Stock pcm help
Old 07-24-2010, 06:34 PM
Turbomike88's Avatar
Default Stock pcm help
Can i use a stock pcm , i have a 02 lq9 motor and harness , i don't have a pcm which one would be best for me to use , the motor has a 88mm turbo and 95# inj. or should i just buy aftermarket
How do you tune a stock pcm do you us a laptop ??
I'm new to the efi , i always have had carbs
Old 07-24-2010, 08:00 PM
BLK02WS6's Avatar
You can use a stock PCM - personally, I would, along with a 2 or 3 bar custom operating system... Yes, they are tuned with a laptop using a tuning software like EFILive or HPTuners. The best PCM to use is a #0411.
How much boost are you running? What kind of injectors are they? What is it going in and what kind of transmission?
Old 07-24-2010, 08:27 PM
1987 Mustang notch , boost will be 10-15 pounds , 95# Delphi injectors , powerglide trans
Do you have pix and more info on which on to use of these... 2 or 3 bar custom operating system
Thanks for your info
Old 07-24-2010, 08:38 PM
BLK02WS6's Avatar
The 2 bar operating system is put into the PCM using the tuning software - and you use a 2 bar MAP sensor and then you can fuel it accurately in Speed Density without a Mass Airflow Sensor. Those injectors may be a bit hard to tune on idle - are they high or low impedence?
Old 07-24-2010, 08:49 PM
low impedence
Old 07-24-2010, 08:55 PM
Whats better to use , AutoCal ,FlashScan V1 Scan and Tune , FlashScan V2 Scan And Tune
Old 07-25-2010, 10:15 PM
Which one of these is the better one or what are more poeple using......... EFILive or HPTuners.
Does anyone have one of these........PCM #0411.
Old 07-26-2010, 07:30 AM
wait4me's Avatar
We have them in stock they are $75 set up to a stock custom os5. Shipping would be about 20 bucks.
You would need V1 hardware, I have a used one laying round for 400 if you want one.
Old 07-26-2010, 09:25 AM
bigboykilroy's Avatar
This may be a stupid question but what is V1 Hardware?
Old 07-26-2010, 12:28 PM
I'm intrested in both , whats the best way to contact you
Old 07-26-2010, 12:30 PM
wait4me's Avatar
just call the number in my sig sometime today.
Old 07-26-2010, 12:52 PM
Called twice and no answer , is there a better time to call
Old 07-27-2010, 01:17 PM
Just tried calling 4 times , i can hear u but that about as far as it goes , i think theres something wrong with the line on you end , i sent you a pm and i'll try calling later.
Mike
