02 TA Replaced Radio now Vats is stopping car from starting???
have you left the key in if you have it will keep adding time to not let it start if its in the vats. pull key and wait 30 mins to be safe. was your factory radio locked? does the light on the dash in def. vent blink? car should start with out radio. how did you power new one? If your old radio was locked car should still start just no radio.
Is it a stick car, maybe you knocked the switch off the clutch. Also check for any blown fuses.
If it is VATs the light would be flashing. The light should come on when you turn on the key they go off. You can measure the resistance of the key with a ohm meter, then wire in the same resistance under the dash with radio shack resistors. I have seen a write up on this somewhere on here.
I like this VATs bypass much better.
I thought the resistance was very pickey like 1% of the pellet value and no start.
but here is the link
https://ls1tech.com/forums/conversio...ts-bypass.html
