The Buck Stops Here (cam surge gone)
Old 05-11-2011, 08:40 AM
SSpdDmon's Avatar
Default The Buck Stops Here (cam surge gone)
Took some quick video last night...think I finally got this thing dialed in to where I want it.
http://www.youtube.com/watch?v=CH6r1T36Whc
Specifics:
Open loop MAF only tune
Z06 MAF with stock MAF curve from Z06 tune
SVO 30lb injectors
Linear injector flow rate (values are ~31.5@0 kPa to ~40@80 kPa)
With the cam, it idles right around 17:1 on the WBO2 (appears lean due to overlap in cam), drives right around 14.2:1 (WB in passenger side - typically runs a little richer), and I can finally say I'm happy!
Old 05-11-2011, 09:12 AM
LS1TECH Sponsor
foff667's Avatar
Cool man, thankfully I had an auto so I just set my tcc to lockup after the surge passed but I was happy with that, must've taken alot of testing to get it to where you are happy with an m6.
Old 05-11-2011, 09:23 AM
SSpdDmon's Avatar
Tell me about it...
Thanks
Old 05-11-2011, 10:47 AM
joecar's Avatar
Good deal
Old 05-11-2011, 09:22 PM
nikon1999's Avatar
good job!
Been trying to tune my car OLSD for 2 years previous, always had issues. Switched to OLMAF this year, leaps and bounds better than the olsd was for me. Just have a few more things to sort out. Everyone says IAT doesn't affect MAF as much, but it really seems to kill my 99.
Old 05-12-2011, 04:27 AM
ctd
ctd's Avatar
What is it like in the lower gears between 1k & 2k rpm?
Old 05-12-2011, 06:58 AM
SSpdDmon's Avatar
Originally Posted by nikon1999
good job!
Yeah - I'm 2 steps away from relocating the sensor so that it doesn't heat soak.
It's similar to the video. I can actually use the gears unlike before. I think there's always going to be a small amount of residual surge that you can't do anything about. But, this is pretty darn close. If I get some time, I'll have a friend shoot some video from the passenger seat....
Old 05-12-2011, 07:24 AM
ctd
ctd's Avatar
I would really like to see the video in the lower gears below 2k rpm.
We just spent hours with mine on Mustang dialing the MAF & VE tables to near perfection. We Tried MAF only OL & CL, VE the same way, then blended. The best @ this point is SP CL & additional fine tuning of the secondary table. That secondary table using TPS noticeable helps in the low load lower RPM buck area's.
I'm really interested in any thing I can do to further improve the drive ability of my 243/247 cam.
Old 05-12-2011, 07:31 AM
BlueThunder2's Avatar
Good job!
Old 06-16-2011, 11:20 AM
SSpdDmon's Avatar
Tried to grab some video while stuck in traffic yesterday. Wasn't able to get out of first gear. But, this is how it was behaving...
http://www.youtube.com/watch?v=U2MnX_ykLeo
After a few weeks of driving it around, I'd say that 98% of the cam surge is gone. There will be times when it acts up a little. But, it's no where near as bad as it used to be or some other cars I've seen/tuned.
Old 06-16-2011, 02:19 PM
ctd
ctd's Avatar
Very Nice.....thats the way it should run.
I've spent allot of time with mine & I think this 102 TB has been kicking my ***. In one of my logs I scaled down the ETC% so I could watch holy was that erratic. I could really imagine how the airflow of that 102 TB in those low position could possibly contribute to buck, surge & want to rip your face off when trying to accelerate as you were in the video. So I cut the desired pedal position tables 50%, that required a bunch of time sorting the follower & adaptive idle tables....I think I have some very positive results from that, just have not had a chance to drive.
Old 06-16-2011, 07:13 PM
Moderator
jimmyblue's Avatar
I've also seen the MAF really clean up idle. Seems to
me the problem is in the VE table, MAP axis taper. The
character of fuel-surge changes if I change the MAP-
slope, I can see MAP yo-yo-ing if the higher MAP is
leaner (lower VE). MAF is just stable. Bouncing MAP
is making a bouncing air mass all the time, has to bother
the running airflow control loop as well as the fueling.
Old 06-19-2011, 01:03 AM
pHEnomIC's Avatar
Any trick/secret/ something different you did?
Ive dealt with that issue in the past but it seems like maf mode took care of it.
Quick Reply: The Buck Stops Here (cam surge gone)
