98 to a 00 PCM swap?
Hey guys,
I am about to swap my good ole piece of **** 98 PCM to a 00!
I do have a print out here,
https://ls1tech.com/forums/attachmen...convert98a.doc
Any other pointers that may make it an easier process? 100+ repins seems like a lot more then I was expecting! I did notice the 99+ connectors are opposite then the 98. I'm just curious to know if anyone has a labeled schematce of what pins are what, there r several things I am not going to need to use! The hole dah cluster minus the tach and ECT are amongst a few!
Any pointers would be appreciated.
When you get in the groove, it will not take very long at all. My first try was 2.5 hours. When I repinned it back to 98, it was an hour. I used a voltmeter lead for my pick to eject the wires. Just get a chair, put a towel over the fender and relax, it really is pretty easy.
I have run into a few problems here. I did the whole repin and followed the directions to a tee, I double, triple, and quadrupedal checked. Gave the vehicle power and no communication with the PCM. My HP Tuners had power from the OBD2 port but I couldn't connect. So I purchased an actual schematic from Alldata on the 98 and 00 harness connectors. I had 5 miss wiring's from following the instructions that were not matching up on the schematic. So I found that wire on the 98 and it was a different color.
The Crankshaft position sensor was yellow on the 98 but is labeled brown on the 00. I had no other loose brown wires that were crankshaft. They were all AC and EGR.The other was the Alternator L terminal which the 98 doesn't even have. The last was the Serial data connector that the instructions said to delete but the 00 has a spot for it and it was dark green on the 00 and tan on the 98. Still plugged in the necessary wires that matched up from the 98 to the 00 and still nothing. The motor cranks over so I know the ignition is working however I cant get a feed from the scanner. Any ideas?
Thanks for your help.
Jake
Jake
Any ideas?
Sorry about the confusion on that. I did reread where some of the wire colors and circuits are going to be different from the 98 then they will be on a 99+. That was my first concern since there were some wires that were different colors then what the 99+ schematic called for. However I think this might be a problem. I have several wires that I do no need to be using so I just left them hanging for the time being. These wires are ones such as all transmission, dash cluster, fuel pump, air pump, AC, EGR and those of the sorts. The only ones I really need are the ignition, injectors and ECT, IAC, IAT, and TPS really minus the grounds and battery voltage. I am guessing that even though these wires are not being used they still need to be pinned in the harness were they are supposed to go.
Any ideas?
Any ideas?
Well I am at a total loss here. The only thing that I can think of is that the PCM I am using is damaged. I have checked rechecked and rechecked and rechecked again and everything is where it is supposed to be. I even bought the actual PCM schematics off Alldatay for a 98 and a 99+ and verified that every connection that was plugged in came from where it was supposed too and everything lined up. When I turn the key i get power and all just no communication to the PCM with my HPT scanner. I can crank the motor over all day but nothing on the communication side. Checked all fuses and they are all good, nothing is blown out. Any other pointers would be appreciated.
Thanks
Thanks
Not sure about that. The Scanner will not read the PCM, The motor cranks and all but Im not trying to start the car. I have a different fuel system all together. VATS keeps the injectors from firing which may be a prob but i cant tell until I can interface with the computer. The PCM works fine too, I put in my buddies car and the interface connected right up no problems. I have gone over every wire again and again and everything is where it supposed to be. All the connectors are in the right spot, the bolts are tied down nice and tight and everything. No issues there. Just need to figure out what the deal is on this.
I took mailing labels when i did mine and pullen out one at a time and labeled them B12 and A25 ect that way you can look back and and figure out which wires go where...
Tire Smoking Tranny Blowing Director
Mine would crank but not fire the first time cause I had to relearn vats or either disable it. But since u can't even get into the PCM it's not that. I would replace all the wire from 98 to 00. Then if it fires start taking out the ones you don't need.
Thanks
