PCM Communication Failure/ VATS problem
Old 07-19-2012, 06:11 PM
Buick LS1's Avatar
Question PCM Communication Failure/ VATS problem
Hello Guys im new here, I live in Guatemala City, Central America. And Im having some problems to start a LS1 engine: (I have no experience wiht pcm or electronic things)
Im building a 1950 Buick, but I Install a 1998 camaro LS1 Engine, Transmision, PCM, Harnes, colum steering, etc. on it.
My problem begin when the guy who make the swap lost the original key, and I have no copys, so we make a new copy without the chip. Then I try to turn OFF the VATS system with the HP Tunners but this is what happens:
The first time I Insall the HP Tunners on the PCM I have no Communications problem between HP Tunner and PCM, I could read all the PCM information the first time, So I proceed to turn OFF the VATS system and when I wanted to burn back the info to the PCM Communication Failure message come on, the HP Tuner does not detect my pcm, it start to say chek if all the cables are connected, etc.
I chek the wires: all are connected (just mock up), I put the car on run position, and I tryed so many times and still having the same problem. Any I deas on what is causing that problem? the PCM may have been damaged or block?
Thanks for any advices, Ideas, Help. and sorry for my English jejeje
Old 07-19-2012, 10:45 PM
MontecarloDrag's Avatar
If you can read, you should be able to write changes.
Unplug battery a few minutes, plug it back and open ignition switch, plug OBD-II cable, wait 15 seconds and try to write-calibration only
Old 07-20-2012, 06:06 PM
Buick LS1's Avatar
I do like you say, tray many times and nothing... There are any chances that the computer may have been damaged?
Old 07-20-2012, 06:25 PM
Buick LS1's Avatar
This is the message im having whit the hp tuner...
Old 07-20-2012, 06:29 PM
Buick LS1's Avatar
Sorry I can upload the picture, im going to try again.
Old 07-20-2012, 07:58 PM
Buick LS1's Avatar
This is the message that I am getting from HP Tuner.
Attached Thumbnails PCM Communication Failure/ VATS problem-descarga.jpg
Old 07-20-2012, 08:16 PM
Buick LS1's Avatar
This is the other message that I've been getting, HELP PLEASE! Thank you!
Attached Thumbnails PCM Communication Failure/ VATS problem-descarga-1-.jpg
Old 07-21-2012, 12:56 PM
Hook a battery charger at low charge and try again.
Quick Reply: PCM Communication Failure/ VATS problem
