ve tuning from 4000 rpm and up
Old 10-24-2012, 06:56 PM
SStressin's Avatar
Default ve tuning from 4000 rpm and up
what is the correct way to tune the ve table from 4000 rpm and up?? i did the ve tuning like the write ups say online till 4000. but they say use a different method and i cant find it.. can anyone help me??
Old 10-24-2012, 08:42 PM
MontecarloDrag's Avatar
The method is the same, but you need a wideband.
If you are using a MAF there is no need to tune VE from 4000 and above, because the MAF takes over at 4000 RPM and the PCM ignores whatever the VE tables have.
There are only 2 scenarios where you want the VE tables to be tuned from 4000 and above:
1- A failed MAF under WOT or when you are at the drag strip
2- If you are going Speed density
For most people is a waste of time.
Old 10-24-2012, 08:56 PM
outkast6991's Avatar
Unless your Maf fails while at wot. Then the hour of your time saves your motor
Old 10-25-2012, 08:04 AM
redtan's Avatar
Yeah like outkast said, what happens if your MAF does fail?
Even with running a MAF, a tune is not complete until you have perfected both the MAF and VE tables. So just because it has a MAF does not mean completely ignore the VE table.
Old 10-25-2012, 09:11 AM
SStressin's Avatar
Ok. Ik now to finish the ve table from 4000-7000 same way i did it from 0-4000 now ik for the maf i have to see where the afr is not what i commanded it to be i have to go in and adjust how much its off by. Now my question is how do ik at what frequencies are at what rpms?
Old 10-25-2012, 10:10 AM
I have no idea how hp tuners is but in efi live you build a map that mirrors the Maf table using your wb Ben to populate the map. Slow steady throttle movements to cover the freq range then multiply by your Ben
In a given freq range
Old 10-25-2012, 10:12 AM
Also compare your curve to a stock Maf curve when done. It should have the same shape with no spikes/ dips
Old 10-25-2012, 10:16 AM
I said it first
Quick Reply: ve tuning from 4000 rpm and up
