calling Don (slowhawk) or any other tuning specialist
maybe you can PM me about this but i know you tuned my camaro with EFI Live and i now have EFI Live and am trying to do the same to my truck. its a 6.7 Cummins so i know its a little different but im assuming its all relatively the same. when i do a system readiness check i keep getting "not ready" for my catalyst monitor and 02 sensor monitor. i have all my emissions stuff disabled BUT from what ive searched and read im supposed to have them enabled but but dont report errors??? also do i need to have these sensors actually plugged in and installed? the weird thing is when i went to get inspected my EGR came up as not ready but now it is ready even though i have it all disabled?
no one on here has any tuning experience??? i find that hard to believe...ya it may not be LS specific but when it comes to emissions systems im sure its all the same. and if youre afraid to post anything about tuning out emissions then please PM me. i need to know what should be "enabled" or "disabled" and still have the sensor monitors come up as "ready"
the more i look into it when i open my tune file and click on the DTC folder the only category that pops up is "parameters". from there all it gives me the option of doing is enabling and disabling DTCs? so if i disable codes does that mean they are no longer reporting? but then what do i have to do to get them to still show up as "ready" in my system readiness check?
oh and correction ya its under diagnostics then i have a DTC subfolder and i go into that and i can only enable and disable things...???
LS1Tech Sponsor
Why would you call me on a board when you can easily find my shop number? LOL
DO NOT SET TO NOT REPORTED,,, EVER
Mass knows this trick and will instantly send you to a state inspection center. Meaning the vehicle has to go back to stock.
I've never spent any time on deisels though.
Or I'm just doing something wrong and not looking in the right spot?
Thanks!!!
ok so ive figured out one thing now am trying to figure out how or what i have to adjust so that my catalyst monitor is "ready" do i adjust the default values? i have catalyst temperature in/out default values and then catalyst lambda in/out default values and then catalyst in/out nitrogen oxide default values??? does ANYONE know what i should do to fool the pcm into thinking my cat is still there? PM me please any info!!! this is the last thing i need to get going and ill be ready to go!
