Built engine, no start! need 99+ wiring swap help
Old 11-16-2013, 10:36 AM
Firehawk896's Avatar
Default Built engine, no start! need 99+ wiring swap help
How's It Going, I Had A Custom Engine Built For My 98 TA, And Have A basic Tune From Speed Inc,42# Injectors Aeromotive Pump, Custom Everything. It Has The Essentials, Fuel Spark And Air, It Started For About 4 Seconds And Now Nothing, It Sounds Like It Wants Too But Won't, Any Help Much Appreciated. I Need To Get This Done By Tuesday For The Dyno Tune
Old 11-18-2013, 02:12 PM
codyvette's Avatar
Last time I had that issue it was two big ole vacuum leaks. Everyone haz those days I guess.
Old 11-19-2013, 09:58 AM
Injector #3 Is stuck Wide Open
Old 11-19-2013, 01:14 PM
SuperC1's Avatar
How did you determine this?
Old 11-20-2013, 01:16 PM
Brought it to a local speed shop and the tested it I would attach an image but my tablet won't let me
I also just swapped my harness, ( I have a 98) to am 01 pcm and engine harness, I can't find any threads on here that are write ups to change the connectors under the pass side for the gauges, so if anyone has a link to that or adapter harness it would be much appreciated.
Also I put the stick injectors back in and the car fired right up, I have to get a coffee reader to see why theres a misfire though
Old 11-26-2013, 04:52 PM
So I'm back To Square 1, Originally It Was A Ground To The Computer, I Haven't Started It For week, Now The Same Thing....HeLP!
Old 11-26-2013, 05:27 PM
9-Second Club
Ed Wright's Avatar
Wow! Another one. LOL
If you insist on the '01 PCM (can't imagine why you would) you need to use your original harness, and simply swap the pins/wires around in the PCM connectors for the '01 PCM. Should not have changed the harness. With what you have there, there is no valid reason to not use the '98 PCM. I have had several nine second customers using their original '98 PCMs.
Old 11-26-2013, 05:44 PM
Burken01's Avatar
Maybe cuz he wants to avoid this lol
Attached Thumbnails Built engine, no start! need 99+ wiring swap help-image-2575817888.jpg
Old 11-26-2013, 05:50 PM
Now, I Had To Put It Back To The 98 I Didn't Want To Play With The Wiring Right Now
Old 11-26-2013, 07:34 PM
9-Second Club
Ed Wright's Avatar
That later PCM will only make your tach slower. No upside at all.
Old 11-26-2013, 07:37 PM
98Pcm And Wiring Harness, It Started Last Week Left The Battery Tenner On It, Now Nothing, It's 26* Out
Old 11-26-2013, 07:46 PM
9-Second Club
Ed Wright's Avatar
Cranks over but won't start? Or starter won't even crank it over?
Old 11-26-2013, 07:48 PM
Yeah exactly
Old 11-26-2013, 08:02 PM
9-Second Club
Ed Wright's Avatar
Which?
Old 11-26-2013, 08:03 PM
Cranks But Went Start
Old 11-26-2013, 08:16 PM
9-Second Club
Ed Wright's Avatar
If it has spark at the plugs, try spraying starting fluid or carb cleaner in the air box. If you have a good scanner, scan it and look for cranking RPM, make sure %TPS isn't high, and that the indicated coolant temp agrees with ambient.
Should be within ten degrees or so. If the temp shows very cold it will try to flood the engine. Spraying something in it won't make it try to start if that is the case. Reading a lot warmer than ambient would like being sprayed.
No cranking RPM (a good scan tool will have this) would likely indicate a crank position sensor circuit or sensor issue.
TPS above 95% shuts the injectors off, aka Clear Flood Mode.
Check all PCM grounds. (engine cranking) Back probe them at the PCM with a digital volt/ohm meter. Should show less than 1/2 volt. Voltage indicates a bad ground.
Good luck.
Old 11-26-2013, 08:17 PM
It'll Work When The Engine Isn't Running?
Old 11-26-2013, 08:29 PM
9-Second Club
Ed Wright's Avatar
What will?
Old 11-26-2013, 08:32 PM
The Scanner, Mine Doesn't Have The Rpm Part
Old 11-26-2013, 08:51 PM
9-Second Club
Ed Wright's Avatar
Yes, a scanner will work even if the engine won't start. They are used all the time to help diagnose why one won't start. Turn the key on and you should see all the parameters. Now, if you have a code reader, instead of a real scanner, it won't tell you much. I would not waste my money on a code reader.
Quick Reply: Built engine, no start! need 99+ wiring swap help
