LM7 PCM Wiring
LM7 PCM Wiring
I am currently doing a LM7/4l60e swap from a 04 tahoe into an 89 fox body mustang. i am looking at the wiring schematic and it shows that all i need to wire B8 to the battery and F7 to ground in order to get the computer running to keep the car on?
your help will be greatly appreciated.
this is what im getting
You will need to delete vats from the PCM file. Then all pink wires will need connected to switched ignition, orange wires from PCM go directly to battery constant power. Then add the 2003-2005 tacc module with the alluminum back plate and truck pedal. That's it for electrical systems. Then it will fire and run. Then add the 02 sensors etc.
Go here for what wires need deleted from a green blue PCM.
https://spreadsheets.google.com/spre...KSkg2Z3c&hl=en
Pretty simple.
Pretty simple.
