2002 Camaro SS Max lean at WOT?
Old 04-18-2014, 04:36 PM
ALLR1SE's Avatar
Default 2002 Camaro SS Max lean at WOT?
I have a 2001 Camaro SS M6 that I received. I hooked up my hp tuner cable up to it to read the tune so I could tune it and I got a 6000 error code. I did some research and it said that the car may have had a handheld tuner hooked to it at one point and had a canned tune. So I tryed pulling the radio fuse as well as cycling the key on and off and had no luck. So I did a write entire putting my buddies 2002 Camaro SS Auto tune in it and downloaded a stock Manual stune from the repository and changed ALL the parameters to match the manual tune and it runs great with everything except WOT. I goes waaaay lean at WOT. At one point I hit 4,000 rpm and it hit PE mode and went to 12.5 afr but it only did it once. Car has SLP intake, SLP MAF, SLP headers and Offroad Y pipe into SLP exhaust. I tried changing the PE tables and had no luck, Any other Ideas I could try? I tried pulling the tune out of my buddies 98 camaro z28 and writing it to the SS but it must have a different program as it wont accept the calibration. Ive gone thru the stock tune 4 times and I know I havent missed anything. All of the sensors seem to be working fine. The throttle only opens 80% it says thru the scanner... could this be part of the problem?
File Type: hpl
Old 04-18-2014, 04:57 PM
Darkman's Avatar
You would probably have more luck by posting this in the PCM Diagnostics and Tuning section of this forum.
Old 04-18-2014, 05:00 PM
motion427's Avatar
12.5afr is not lean at all for a naturally aspirated LS engine.
Old 04-19-2014, 04:15 AM
ALLR1SE's Avatar
It hits 20.** afr at wot. It only hit 12.5 once and that was after 4k rpm. I will post this there. Thank you
Old 04-19-2014, 06:43 AM
Old Geezer's Avatar
Maybe try the correct forum??
Old 04-19-2014, 07:03 AM
jmmcamaro2002's Avatar
Did you check your fuel pressure WOT. I have a similar problem and my fuel pressure drop from a baseline of 55 psi to approximately 30 psi. Time for a new fuel pump, just waiting to get nerve to drop my tank to replace it.
Old 04-19-2014, 09:13 AM
hodge9386's Avatar
if its only reading 80% max throttle it might not be going to pe. take the maf and everything off and have somebody push the throttle to the floor and see if its actually opening all the way. if it is you might have a bad tps sensor.
Old 04-19-2014, 09:24 AM
sreve's Avatar
TPS 4.6v ish WOT
20.9 is the natural oxygen level
So a 20:1 afr makes me think the wide band is lying to you.
Old 04-25-2014, 03:39 AM
ALLR1SE's Avatar
Well we found out the SLP MAF is junk. Ran it unplugged and in OL and all is good.
Old 04-25-2014, 04:40 AM
Exidous's Avatar
Was the MAF table tuned? Just plugging it in doesn't work out well.
Quick Reply: 2002 Camaro SS Max lean at WOT?
