ltrim question
ltrim question
This morning with my cutout capped I logged my drive to work. Last night I adjusted my IFR table down to 90% of the stock settings and the average Ltims of 645 records was -3.03696 and -2.12019 (B1 B2). Is that TOO negative? I'm being told that I want my ltrims as close to 0 as possible. I could have sworn I read somewhere in here that the target range is -2 to -8.
Give the car a little more learn time so the LTFT will settle out. A day or two of driving, 100 miles, etc. But they seem to be good. Most set there LTFT's between -8 to 0.
what should the ltrims be at wot? 0 mine are at 7. should i work on it ot get at 0 at wot and what do i need too chage to do that im new at this tunning stuff thanks
eddie
eddie
eddie
eddie
Dave
I've heard from some local guys that you want your ltrims as close to 0 as possible at all times. However I'm reading that you want them in the -2 to
-8 range within fuel cells 6-14. They should read 0 at WOT.
Mine are at 0 at WOT, and in the -3 to -5 range within the fuel cells 6-14, and an overall average of -1.1 and -.8...at least that was my most recent log.
Moderator
As long as they are being compensated, it doesn't really matter. I like mine slightly negative, so it STAYS that way with varying humidity and temparature. Dead-on zero makes me think you will sometimes run slightly positive with weather variances.
