Gen 4 engine with Gen3 PCM/Harness questions
Hey guys,
I read through all the pages about putting ls3 into body, but I'm not clear about some issue with the sensor. Here are my questions and please help before I dropped the engine in. My engine is a l92 converted to ls3 ext ext .I swapped the reluctor wheel to 24x.
1. Timing cover kit.
I bought this
http://www.coloradospeed.com/engines...3-p-11539.html and this for the harness
the discussion on the thread stated that i need earlier model cam sprocket and earlier model ls2 cam sensor to work on my 411 cpm like this one http://www.lingenfelter.com/mm5/merc...9#.VbTVjutbkUU
The parts # correlates with the one discussed.
So do I need to get a different cam sensor or will it work with the harness that I bought on ebay using the timing cover kit that I bought?
2. Map Sensor
Some people said that the ls3 map sensor will not work. Some said it will with the harness that I bought.
http://www.ebay.com/itm/321813356202?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITSome said I can use the ls1 map sensor with a vacuum hose?? where do I mount the map sensor if using the ls1?
Please help thanks!
I bought this
2. Map Sensor
Please help thanks!
Hey guys,
I bought this
I bought this
That's the right part for the timing cover.
According to this the newer tan sensor will also work on the 1x reluctor wheel. You also need the 1x cam gear if ya don't already have it. It looks like this:
2. Map Sensor
GM Map Sensor Adapter Harness Connects LS1 LS6 LS2 to LS3 LS7 Style Map Sensor | eBay
Please help thanks!
Please help thanks!
Awesome man thanks! I have the 1x cam gear. And I'm using two piece timing cover. I just wanna make sure that I can use the sensor that comes with the timing kit before I put all the accessories drive togather and ended up throwing a code.
How do you make a bracket for the ls1 map sensor?
