Wideband
Old 03-11-2016, 08:02 AM
RBCUDA's Avatar
Default Wideband
I wanting to install a wideband with a gauge so I can monitor it all the time. What do you recommend that will be accurate and have a quick response time? Really looking for something that can go in a gauge pod. Thanks guys.
Old 03-11-2016, 12:13 PM
tadams72's Avatar
If you've got true duals I'd recommend the Innovate Motorsports DLG-1. It monitors both banks simultaneous, is programmable, and has data outs for logging with their software or with others like EFI Live. If you are running a single exhaust then take a look at their LC-2.
Old 03-11-2016, 12:46 PM
RBCUDA's Avatar
Has anyone read about the new AEM 30-0300 X-Series Digital? Looks pretty promising. They claim it's the fastest on the market. You also have the option of doing a free air calibration.
Old 03-11-2016, 01:12 PM
tadams72's Avatar
Nope but Innovate does free air calibration as well.
Old 03-11-2016, 01:24 PM
RBCUDA's Avatar
I knew they did. That was the main complaint I've seen about AEM, was you couldn't. I had a innovate in the past, and had a lot of problems with it.
Old 03-11-2016, 01:57 PM
tadams72's Avatar
Well if you've got a sour feeling towards them that's understandable. I've had very good results with my setup. Maybe someone will have some other options for you.
Old 03-11-2016, 02:07 PM
RBCUDA's Avatar
Thank you for your input. I do appreciate it.
Old 03-11-2016, 08:24 PM
tadams72's Avatar
No problem. Good luck and let us know if you come across something great.
Old 03-11-2016, 08:27 PM
kingtal0n's Avatar
Whatever you use, remember to keep the wideband away from any turbine and high EGT. The instructions should say something like that, but sometimes we see OEM location threads and think "why not take out the narrowband and install the wideband here, right behind the turbine?".
Old 03-12-2016, 08:27 PM
dr.mike's Avatar
I've been doing re-flashes on the new AEM 30-0300 gauges to work directly through OBDII. So far, it has been working great for people with HPTuners and DashDAQ devices. Looking to test with other devices.
PM me if you have one that you would like to have re-flashed to try the OBDII interface.
Old 03-13-2016, 02:09 PM
RBCUDA's Avatar
I have EFI Live. I'm guessing that it will work since it has 0-5 volt output. Will just need to figure out to to setup EFI Live to work with it. I'm really thinking about trying out the 30-0300.
Old 03-13-2016, 02:22 PM
JimMueller's Avatar
I had the Innovate LM-1 years ago, eventually had problems with the solder connections coming loose on the board. I was not impressed with their customer service.
So I switched to a NGK AFX which I still use today. Although that model was replaced by NGK with a lower quality unit, Ballenger Motorsports offers a upgraded version of the original AFX, named AFR500, which is what I would buy if I was starting from scratch.
Old 03-13-2016, 06:09 PM
tadams72's Avatar
Don't forget the Flashscan V2 accepts digital inputs as well. I use those for faster and more accurate data transfer.
Old 03-13-2016, 08:43 PM
dr.mike's Avatar
Can it accept the raw CAN data from the 30-0300? Or, will it take the emulated OBDII lambda data from the modified gauges ( PID.24 etc. )?
_
Old 03-13-2016, 11:14 PM
tadams72's Avatar
_
Swimming pool is getting deep for me but I know who can answer that. Hit up joecar here. He is an EFI Live guru.
Old 03-14-2016, 07:57 AM
RBCUDA's Avatar
I have the V1, so I will need to use the 0-5 volt output.
Old 03-14-2016, 10:41 PM
dr.mike's Avatar
BTW ...
From AEM :
The results from the "independent testing lab" for response times.
Old 03-16-2016, 10:04 PM
RBCUDA's Avatar
I ordered one of the AEM 30-0300. I'll give it and try and see what its like.
Old 03-16-2016, 11:11 PM
dr.mike's Avatar
Do you need me to flash the OBDII code onto it ?
Old 03-18-2016, 02:59 AM
joecar's Avatar
Default Wideband
Can you post the user manual pdf for this particular AEM wideband controller/gauge combination...
EFILive V2 can read the AEM controller's serial comms output as long as long as the gauge does not use it (i.e. if the gauge uses analog signal);
if the gauge uses serial comms from the controller, does it repeat it as an output...?
I need to see the manual.
Quick Reply: Wideband
