2002 430LSX vac level?
Old 10-18-2016, 03:41 PM
Patsy57's Avatar
Default 2002 430LSX vac level?
I was wondering at idle what the proper vac level is? My gauge reads 5 and low at idle.
Thoughts?
430LSX race motor
Running Na
With a blower cam just no post yet
Old 10-18-2016, 09:16 PM
Super Hulk Smash
JakeFusion's Avatar
What cam is in it? 5" hg is pretty damn sorry. But if it's a race motor... It'll probably scream up top.
How does it drive?
Old 10-18-2016, 10:49 PM
1970camaroRS's Avatar
What are the specs on this "blower cam"?
Old 10-19-2016, 12:22 PM
Patsy57's Avatar
I'm an idiot i didn't have the vac line connected to the vac block.
I'll send an update tonight
Old 07-15-2017, 10:13 AM
Patsy57's Avatar
How does it drive?
Current cam is:
Duartion @.050 238/247 .637/.629 Lobe SEP 112 Degree +4 ADV)
im seeing 20" at idle
it drives bumpy but needs a retune.
the blower isn't on yet and the can is a blower cam. Is that the normal amount of vac at idle? Gauge says low vac.
Old 07-15-2017, 01:52 PM
Lsxford's Avatar
Originally Posted by Patsy57
Current cam is:
20" at idle seems about right with that size cam to me. But i am no expert, you have more vacuum than me and my cam is a 238 and 625 lift on both sides iirc
Old 07-15-2017, 06:47 PM
Patsy57's Avatar
What vac level do you run?
Old 07-15-2017, 06:53 PM
Old School Heavy
speedtigger's Avatar
Thoughts?
430LSX race motor
Running Na
Current cam is:
Those are some odd looking 430" blower cam specs. What head, intake and blower?
Old 07-15-2017, 07:43 PM
Patsy57's Avatar
Blower is an F1R cog drive. Heads are AFR 225 cathedral port, intake is a FaST 102
Old 07-15-2017, 07:58 PM
Old School Heavy
You have a big engine with smallish heads, a long runner intake and an aggressive blower. If I have spec'd that camshaft, it would look more like 242/258 on 116. That cam you have there will likely be RPM limited, and leave power on the table.
Old 07-15-2017, 08:59 PM
Patsy57's Avatar
I'm going to be upgrading the heads soon gonna go with AFR 235 heads or TFS 245
Old 07-18-2017, 11:25 AM
Super Hulk Smash
JakeFusion's Avatar
I'd move over to an LS7 head on a 430.
And that cam looks like a good NA cam for a streetable 402.
Old 07-18-2017, 01:23 PM
Patsy57's Avatar
When looking at LS7 heads what do I have to worry about in regards to valve placement ?
Old 07-21-2017, 11:00 AM
Lsxford's Avatar
i see around 13-15 inches 750 rpm idle, but im just starting to get the tune lined up
Quick Reply: 2002 430LSX vac level?
