IAC counts always 0? Idle issues after heads/cam
Both of the plugs to the throttle body (Jantzer ported) are hooked up. The counts are dead on at 0 always when I log with atap. The car has trouble finding a nice steady idle sometimes...
If your IAC counts were really 0 your idle speed would more than likely be wrong, and your check engine light would have come on. Most likely you just can't read it. I could not read them with Autotap on my 98. HPTuners can read it though. Use IAC g/sec, and see what it says. Does your idle ever hunt at all?
You can always check for binding/carbon buildup on your throttle body too.
