Tuning GURUS....what does it mean when the speedo needle does this? VIDEO.UPDATE FIX
Started tonight:
Its jumping around erratically. And exactly when this started my car sounds like it bogging down ONLY when I go into Lock-Up in either "Drive" or "Overdrive".
Overdrive boggs down and vibrates much worse then "Drive".
All other gears seem normal. Its just the second it goes into Lock-Up.....it boggs and feels like wheel hop.....
SES came on also.....have not checked it yet, every place is closed already.
EDIT.....Damn video won't upload.....
FIX:
Front spark plug wire drivers side....fell off at the coil. Popped it on....problems fixed.
FIX:
Jake.....
Just got it done. Took over an hour to upload to YouTube. Strange.
Here it is: I'm cruising steady at 20mph through a school zone.....then I get through it and speed up slowly.
Just read a few things on some forums...possibly a failing speed sensor in the transmission.....
Save the manuals!
Given the intermittent oil pressure gauge problem the other day, I'd say that (even though your cluster has been fine until now) you have a cluster problem or that you having a wiring issue somewhere.
If you can address if the check gauges light came on when your oil pressure gauge crashed, that's going to tell a lot about where to check first.
My tranny builder says it might be the speed sensor in the tal shaft.
Leaving now to get the code read....if it's the speed sensor code than I think that's the culprit.......
NO WAY anyone could have guessed where this problem was coming from.........another example of how wacky these PCMs are and the crazy symptoms and signals they can send out all over and through the entire system.
I went to Advance Auto just now. P0133 and P0153 and one other 02 sensor cose. 3 codes, all for 02 sensors Bank 1 and 2 front sensors.
So I drive home to change them, I have 2 new Densos at home.
So....to recap......speedo needle flicking and jumping all over the place and my converter lock-up in both "DRIVE" and "Overdrive" is all messed up bucking and vibrating like crazy.
I popped the hood......the forward most spark plug wire on the drivers side was off the coil. Popped it back on......everything is perfect again.
There's not a mechanic in the world that would ever say this causes lock-up issues or a speedo needle flicking and jumping around.
.....This wire fell off last night....I know this because I drove by my ceramic header coaters shop yesterday to show him my new 1 7/8" headers that he coated and I installed about 6 months ago. The wires were all on. That wire fell off last night......
Video:
Video:
wssix99......
So after I put the plug wire back on I went for a 30 minute drive to pick up some drag radials for tonight....going to Moroso to run this thing.
I figured I would just put two new 02 sensors in when I got back home. On the way back the SES light went off. So I decided to not put them in.
So a plug wire falling off causes the speedo needle to flick all over the place. Cause the lock-up ONLY to not work, but all other gears work fine. And it makes BOTH banks run rich, which in turn throws 02 sensor codes....BUT does not tell me a cylinder is not firing. The richness makes sense.....but the most experienced PCM designer geek at General Motors would never guess it would affect converter lock-up in OVERDRIVE but let the other gears run normally and make the speedo needle flick and jump.
These PCMs are monsters.......LOL
OH....to your question about the CHECK GAGES ligfht....it went off as soon as the SES light went off while driving home today. So yes, its always off unless there's an issue.
Save the manuals!
The high voltage arc coming off a loose or flailing spark plug wire can to a lot of funky things to other circuits around it.
That should confirm your gauges are good, then and you can turn your attention to the engine bay.
They would tell you that you have wiring problems and that you'd need to find evidence of at least one other person in this world having these issues before you could even start to make wild generalizations about patent defects in PCMs.
Unless the coil can shoot the spark 6-7 inches into the air, then maybe it was hitting the strut tower or the ABS box.
