Knock knock. Whos there? Knock retard who? GO AWAY ALREADY!
So anyways, I still have knock. Go figure with my car being a 98 and all. Stock timing, O2s 898-930, I replaced the tensioner with a Katech (belt was getting thrown anyways), I ran top engine cleaner through last night. I have been trying to find any place that could be causing any type of rattle. It still has knock retard usually 4-5 degrees. I have pulled timing before, and that didn't help. I don't get it. I have some NGK TR55s sitting here in case I decide to pull the Bosch +4s (maybe a misfire?) I am at a loss. I know the stock O2s are not dependable. Should I add more fuel and see if it goes away? If so, how is the best way to add from low/moderate throttle to wot? Should I just write it off as false knock and disable knock retard at that RPM? I will attach a screen shot of what I am seeing....
Originally Posted by jimmyblue
Are these the original '98 knock sensors, or have
you already gone to the later, less false-prone
ones?
ones?
http://users.adelphia.net/~someoneel...16JUL04_01.zip
I switched to the modified fixed orifice PCV. I can't imagine there is much if any oil getting through that tiny hole. And even if there was, the top engine cleaner yesterday should have taken care of it...at least for today. Don't you think?
Originally Posted by Nic00Z28M6
Welcome to the 98 cars. Pretty much every 98 I have come across has had **** tons of false knock. Many of them were pretty much just referencing the low octane table full time as well.
Originally Posted by BlackWS6LS1
I have the same issue with my 98. I also have HP tuners, what is the best way to desensitize at a certain RPM?
Thanks
Tom
Thanks
Tom
