help!! passenger side VERY rich, drivers side fine
Well I figured I would see if you guys can figure out what the problem is. Here is the background -- just finished installing a twin turbo setup on my 2000 trans am. The passenger side manifold heats up to red hot after idling for about 5 minutes -- meanwhile the drivers side is perfect.
So after checking everything mechaical and fuel wise (pressure, leaks, injectors, etc)I'm down to the tuning. My 02 readings on the drivers side are in the 450 mv range, and the passenger side is reading 900mv. So my question is how can the one side be getting more fuel than the other?? There is no way in the computer to seperate bank to bank correct?
ANY and I mean ANY ideas would be greatly appreciated as I am down to my last straw.
I have a similar question, but my readings aren't so far apart. Is it normal to see 890 on one bank and 920 on the other, or should they be closer and stay more towards equal at WOT. Maybe my sensors were damaged like you mentioned to classic?
sry to highjack
sry to highjack
tried 3 different 02 sensors all with the same results. Been through the whole think over and over looking or an exhaust leak. If you look in my posts in the Forced Induction section you will see a lot more detail about whats going on if that helps.
LS1Tech Co-Founder
If the 02 value sits at 450 all the time it's not working. That is the default value. You in that case since you changed the sensors have a burned or messed up 02 harness. The passenger side 02 harness is in that foil wrapped cluster that runs down by #6. My guess is that burned one of those wires. Have you popped a fuse too?
Moderator
With very different exhaust temps you will have very
different narrowband O2 sensor outputs. Not to be
trusted, as far as any bank-bank difference they
might imply.
Is there any plumbing difference that might put more
backpressure on the passenger's side? Different (or
single) wastegate, etc.? Pressure = temperature to
some extent (PV=nRT) and the less the exhaust gas
can expand, the hotter it remains.
might imply.
Plumbing is the same both ways.
PSJ -- Haven't popped any fuses, 02 sensor is working (starts at default then readings level out after it heats up).
